4321 Bronze Donating Members 257 Member For: 11y 2m 20d Posted 12/09/18 10:04 AM Share Posted 12/09/18 10:04 AM These cars have only 1 temp sensor, in the back of the head. If it is not working correctly it will show up on the temp guage- if its been running for 10 min & it says cold I would smell a rat! On the scan tool you should be able to read the O2 sensor, what readings are you getting? , should be between 0.1 to0.8v just remember this info is coming from the ecu so if its wrong 1 or more sensors are sending wrong info. Check your stf trims they should be around 0 (+or_ 5%) If your 02 reading is wrong (ie reading lean) the ecu will add fuel (positive fuel trim) to try & fix the 'problem" While looking at the fuel trims add another earth to the engine (1 jumper lead from batt (-) to a engine earth) & see if the stft changes (it shouldn't) Link to comment https://www.fordxr6turbo.com/forum/topic/94258-running-rich-poor-economy/page/2/#findComment-1663940 Share on other sites More sharing options...
Ascendancy254 New Member 7 Member For: 6y 9m 4d Posted 12/09/18 11:04 AM Author Share Posted 12/09/18 11:04 AM Hi 4321 Much appreciated! The O2 sensor generally reads 0.92ish at idle (regardless of temp etc). Theorhetically, how long should it take for the car to reach op temp? I feel it seems a little long but it does get there and generally sits about 1/3 on the gauge. Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/94258-running-rich-poor-economy/page/2/#findComment-1663941 Share on other sites More sharing options...
Box stock T. Member 1,384 Member For: 10y 2m 8d Posted 12/09/18 11:22 AM Share Posted 12/09/18 11:22 AM All else fails. Trade the ute. $2500 Personal loan $ 6000 ( $80 p/w) _______ Buy Ba XR6T $8500 ute or sedan. Result. ----------- $80 per week for loan $80 per week for fuel. Endless fun per week... weeeeeeee Link to comment https://www.fordxr6turbo.com/forum/topic/94258-running-rich-poor-economy/page/2/#findComment-1663944 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 4m 17d Gender: Not Telling Posted 12/09/18 12:08 PM Share Posted 12/09/18 12:08 PM 44 minutes ago, Box stock T. said: Buy Ba XR6T $8500 ute or sedan. Take 2 to 4 k from that and you've got a deal. Link to comment https://www.fordxr6turbo.com/forum/topic/94258-running-rich-poor-economy/page/2/#findComment-1663946 Share on other sites More sharing options...
El Andrew Gold Donating Members 2,039 Member For: 10y 1m 24d Gender: Male Location: Canberra ACT Posted 12/09/18 01:18 PM Share Posted 12/09/18 01:18 PM You might need to take $2k off that trade price for a farked n/a too!+1 for checking short term and long term fuel trims with a scan tool Link to comment https://www.fordxr6turbo.com/forum/topic/94258-running-rich-poor-economy/page/2/#findComment-1663947 Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 11y 2m 20d Posted 12/09/18 07:33 PM Share Posted 12/09/18 07:33 PM 0.9 at idle is rich, it should oscillate between 0.2 (lean ) & 0.8v. Like I said you have to work out if it's running rich or if the sensor is wrong. You've changed it 3 times so I'd say that's not the problem. This is why reading your fuel trims is a usefull bit of info. 0% is the base program and it's +or - is how much the ecu is having to change the program to oscillate around 0.45v (which is stoichiometric 'perfect' mixture) it should go either side of this value trying to keep as close as it can to this reading at idle & cruise (it will go rich on acceleration, 0.8-0.9v) Next is to get your fuel pressure checked. stft are whats happening now & ltft are what it's modifying the program based on what it's seen over time Link to comment https://www.fordxr6turbo.com/forum/topic/94258-running-rich-poor-economy/page/2/#findComment-1663949 Share on other sites More sharing options...
Ascendancy254 New Member 7 Member For: 6y 9m 4d Posted 13/09/18 04:40 AM Author Share Posted 13/09/18 04:40 AM Thanks 4321, I'll check it out over the weekend! Why would running an earth from battery to engine change anything? Is there a known farthing issue with these cats? Cheers again for the help! 1 Link to comment https://www.fordxr6turbo.com/forum/topic/94258-running-rich-poor-economy/page/2/#findComment-1663962 Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 11y 2m 20d Posted 13/09/18 09:23 AM Share Posted 13/09/18 09:23 AM Theorectly it should make no difference but if there is a problem with earthing (remember we are dealing with less than 1 volt) it can't hurt 1 Link to comment https://www.fordxr6turbo.com/forum/topic/94258-running-rich-poor-economy/page/2/#findComment-1663972 Share on other sites More sharing options...
stancez New Member 14 Member For: 3y 9m 22d Posted 24/08/21 05:46 PM Share Posted 24/08/21 05:46 PM (edited) Any update to this, I've got a MKII 04 XR6T and have been dealing with the same issue, and similarly replaced alot of the same parts with no success. Just purchased Forscan OBD and from what I could see no significant faults that would cause this issue. Just purchased another o2 sensor in the hopes that the previous one I installed might have been d.o.a any help would be great! T.I.a. Edited 24/08/21 05:47 PM by stancez 1 Link to comment https://www.fordxr6turbo.com/forum/topic/94258-running-rich-poor-economy/page/2/#findComment-1707100 Share on other sites More sharing options...
BarraT Member 34 Member For: 5y 4m 26d Posted 18/03/24 09:46 AM Share Posted 18/03/24 09:46 AM Yes, I too would like to know what the solution, Can someone please let us know if Ascendancy254 solved the problem ! Link to comment https://www.fordxr6turbo.com/forum/topic/94258-running-rich-poor-economy/page/2/#findComment-1722469 Share on other sites More sharing options...
