FIXR7 Member 116 Member For: 15y 14d Gender: Male Location: Perth Posted 26/06/14 01:46 AM Share Posted 26/06/14 01:46 AM G'day folks,I'm looking at some Enkei GTC-01's in 19". Trouble is they only have 9.5" +22 and +42 in stock or 9" +18 for the front of the car. The 8.5" +22 is out of stock. Now my ute is quite low. Should I wait till there's an 8.5" in stock or go with one of the others? maybe the +42 and space accordingly?Also is a 10" +22 pushing my luck for the rear without rolling the lip?Cheers. Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/246/#findComment-1481016 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 7m 12d Gender: Male Location: Perth Posted 26/06/14 02:10 AM Share Posted 26/06/14 02:10 AM On a UTE (FG) 10 +22 should be fine, but maybe one of the ute boys can confirm. As for front the 9 +18 (146mm backspace)will sit 3mm closer to the strut than the 8.5 +22. You should have plenty of room on the inside as stock 8 +36 has a 151mm backspace. Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/246/#findComment-1481021 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 11m Gender: Male Location: OZ Posted 26/06/14 02:12 AM Share Posted 26/06/14 02:12 AM (edited) 9" +22 will be fairly flush. Should look good. Front that is. Edited 26/06/14 02:13 AM by IH8TOADS Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/246/#findComment-1481022 Share on other sites More sharing options...
TomT Spooling Member Donating Members 961 Member For: 13y 6m 2d Gender: Male Location: Blue Mountains, NSW Posted 26/06/14 02:50 AM Share Posted 26/06/14 02:50 AM Apologies if already asked.What's the biggest 18" wheel/tyre I can fit under the rear of an fg sedan with SSL/SSSL spring combo. Thinking 18x10 or 10.5, want tyres to be at least 285s.If not possible under stock guards, what can you get under with light guard work? Again, 18s and lowered. Thanks Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/246/#findComment-1481029 Share on other sites More sharing options...
FIXR7 Member 116 Member For: 15y 14d Gender: Male Location: Perth Posted 26/06/14 04:15 AM Share Posted 26/06/14 04:15 AM (edited) Thanks Lads,According to this; http://www.willtheyfit.com/index.php?width=245&aspect=45&diameter=19&wheelwidth=8&offset=36&width2=245&aspect2=45&diameter2=19&wheelwidth2=9&offset2=20#contentThe wheel will stick out 30.7mm further with the 9" +18 wheel and 33.1mm with the 9.5"+22 both with around 5mm further from the upright on the inside.30mm out seems like a lot? no?Here you can see the lowness of it.... Edited 26/06/14 04:24 AM by FIXR7 Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/246/#findComment-1481042 Share on other sites More sharing options...
FIXR7 Member 116 Member For: 15y 14d Gender: Male Location: Perth Posted 26/06/14 04:18 AM Share Posted 26/06/14 04:18 AM (edited) Looks like the 5mm inset won't be a problemo....My mistake it's actually 5mm further away so...even better! Edited 26/06/14 04:23 AM by FIXR7 Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/246/#findComment-1481043 Share on other sites More sharing options...
.Stripes. All stock bar the k&n panel filter Silver Donating Members 8,061 Member For: 13y 2m 26d Gender: Male Location: Perth Posted 26/06/14 10:25 PM Share Posted 26/06/14 10:25 PM Looking for some advice from those of you with more knowledge of this than me. According to section 4.2.2 of VSB14, regarding Wheel Attachment "Modifications to disc brake callipers, hubs and suspension and steering components to enable the fitting of replacement wheels must not be undertaken."This somewhat, legally, limits my ability to run a 10mm control arm spacer on the rear to fit a 295/30/19 tyre on a 19x10 +45 rim.Will a 295/30/19 tyre on a 19x10 +40 rim fit in on a lowered FG with rolled guards and no crazy camber (I.e. full contact patch)? Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/246/#findComment-1481190 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 7m 12d Gender: Male Location: Perth Posted 26/06/14 11:14 PM Share Posted 26/06/14 11:14 PM Looks like the 5mm inset won't be a problemo....My mistake it's actually 5mm further away so...even better!Your car is too clean 2 Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/246/#findComment-1481200 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 7m 12d Gender: Male Location: Perth Posted 26/06/14 11:16 PM Share Posted 26/06/14 11:16 PM Thanks Lads,According to this; http://www.willtheyfit.com/index.php?width=245&aspect=45&diameter=19&wheelwidth=8&offset=36&width2=245&aspect2=45&diameter2=19&wheelwidth2=9&offset2=20#contentThe wheel will stick out 30.7mm further with the 9" +18 wheel and 33.1mm with the 9.5"+22 both with around 5mm further from the upright on the inside.30mm out seems like a lot? no?Here you can see the lowness of it....It will be fine. Back wont be an issue. Utes have heaps of room. FG front is different to BA BF. The offsets you posted will be fine. Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/246/#findComment-1481201 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 7m 12d Gender: Male Location: Perth Posted 26/06/14 11:20 PM Share Posted 26/06/14 11:20 PM Looking for some advice from those of you with more knowledge of this than me. According to section 4.2.2 of VSB14, regarding Wheel Attachment "Modifications to disc brake callipers, hubs and suspension and steering components to enable the fitting of replacement wheels must not be undertaken."This somewhat, legally, limits my ability to run a 10mm control arm spacer on the rear to fit a 295/30/19 tyre on a 19x10 +45 rim.Will a 295/30/19 tyre on a 19x10 +40 rim fit in on a lowered FG with rolled guards and no crazy camber (I.e. full contact patch)? That combination 19 x 10 +40 with 285 fits on BA BF so should fit FG. Maybe stick with 285/30. Can you test fit. I know the rim will fit and be close. Its just how much the tyre bulges. Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/246/#findComment-1481202 Share on other sites More sharing options...
