  • Legacy Donating Member
  • Member For: 11y 7m 24d
  • Gender: Not Telling
Posted
Waste of money for a street car imo but nothing wrong with using the right tool for the job especially if you're not confident with tapping them shut.
  • Dropping a turd
  • Member For: 18y 10m 26d
Posted
Just buy the correct pre gapped plugs
  • Member For: 12y 3m 14d
Posted
What do they cost?
0.9 is the "correct" gap but 0.7 people are recommending which I've not seen on the shelf.
Anyway so far people have recommended:
Gap plugs
Flow test injectors (this is a last resort)
Anything else?
As everything is pretty new I'm feeling like it might be something more..
Posted
Fark knows. I saw a screw type plug gapper on ebay for over 200 usd.
Just tap them for now and you'll be fine.
0.9 is only correct for a stock car.
I had stock plugs blow out when I went over 12psi and 12:1 afr. I took them to 0.7 and it was sorted.
Posted
Ok I'll give it a shot.
Why do you think this wasn't an issue previously?
Posted
Maybe the misfiring cylinder has fouled the plug slightly?
Think back to the various things that are different with your car since it ran properly. One of those changes could be the culprit.
Posted
That's what threw me, I haven't touched the tune or components in almost ~8 months then it just started happening making me assume a coilpack failure. But after new plugs, coils no love, fixing the cover and ensuring the the ECU plugs were in correctly (it has been out before), replugging in all the injectors fixes the idle but introduces the on boost missfire.
I've smelt petrol for a while now (I need to look at this as well) but as it was already there its probably not related to the miss.
I'll try gapping the plugs first then work my way through the list.
Cheers for the help guys.
  • Dropping a turd
Posted
0.7 for tuned car. Isnt you car tuned???????
Think these are on the shelf at any FORD dealer
  • Like 3
