karlp2 Member 81 Member For: 13y 1m 17d Gender: Male Location: Auckland, New Zealand Posted 06/08/16 11:27 PM Posted 06/08/16 11:27 PM (edited) G6ET... 109ks on the clock, cars only had an entry level tune and has always been regularly servived. When driving it cold at about 50km/h if I slightly increase the acceleration I can briefly hear and feel a shudder and vibration. I can't pinpoint it but suspect it's coming from either the diff or gearbox. It goes in for a service tomorrow and I wouldn't mind your thoughts on what it might be? I'm hoping it's not the auto slipping. It only does it when cold and at low revs - like around 1400rpm Thanks for your help. Edited 06/08/16 11:36 PM by karlp2
EvilDaifu Cruise Whore Moderating Team 5,130 Member For: 21y 1m 29d Gender: Male Location: Melbourne Posted 08/08/16 04:33 AM Posted 08/08/16 04:33 AM Just wondering when this started happening? Was it after you had the tune? That might help some others to give their considered opinion. 1
discostig Manual mode ________________________ All day, erryday Legacy Donating Member 13,798 Member For: 18y 10m 10d Gender: Male Location: Probably above atmospheric pressure Posted 08/08/16 05:21 AM Posted 08/08/16 05:21 AM Ever had the ZF fluid and filter changed? I get shudder in mine if it's the first few minutes of the day and I load it up too much but it's no longer a stock box - different clutch pack materials and different oil (Transmax Z). Oh and it cops 50% more power than stock fairly regularly.
Lewis New Member 19 Member For: 10y 4m 22d Posted 08/08/16 05:23 AM Posted 08/08/16 05:23 AM I have the same problem on my ute so it's probably not the rear end as they are different. I was wondering about the universal joints? lewis
karlp2 Member 81 Member For: 13y 1m 17d Gender: Male Location: Auckland, New Zealand Posted 08/08/16 12:22 PM Author Posted 08/08/16 12:22 PM 7 hours ago, EvilDaifu said: Just wondering when this started happening? Was it after you had the tune? That might help some others to give their considered opinion. It's been tuned for about a year, I've only just noticed the issue, thanks
Lewis New Member 19 Member For: 10y 4m 22d Posted 28/10/16 03:37 AM Posted 28/10/16 03:37 AM has the vibration issue gone for you Karlp2? if so, could you let me know what it was as I still have the issue. Lewis
Gsexxy New Member 1 Member For: 7y 3m 27d Posted 07/06/19 04:28 AM Posted 07/06/19 04:28 AM My g6e turbo is having the same issue, found any suggestions? Have new Gibson heavy duty drive shaft and unis fitted but noise is still there and only while driveline is cold...
MBAF Legacy Donating Member 2,156 Member For: 10y 1m 19d Posted 07/06/19 04:33 AM Posted 07/06/19 04:33 AM Checked your engine and transmission mounts?
Gsexxy New Member 1 Member For: 7y 3m 27d Posted 07/06/19 08:57 AM Posted 07/06/19 08:57 AM Yeah they seem fine, it sounds more like a grinding vibration, like something is not meshing properly which I guess if there were slop in either mounts itcould cause the noise 🤔 Once car is all warmed up it completely goes
