G6E Turbo replacement????
Featured Replies
#1
Hey Guys,
So this weekend my turbo has completely shat itself. Started making all sort of howling, and whistling noise and it just rattling badly.. I think I have been pretty unlucky with this one as its only done 69k kms but is run at 18psi daily and had decent power.
Anyway onto the replacement, Ive been researching and have come up with the GTX3584R by MAMBA as a good replacement as it passes the price tickbox. I want to go bigger power and want something around low to mid 400's on pump 98. I also don't want to loose too much down low so I am hoping the spool is not too much worse then the standard GT 3576.
Any advice guys? Really want to try and keep this replacement + tune under 2k if I can.
  • Replies 159
  • Views 29.8k
Most Popular Posts
  • In the spirit of continuing this thread of my learnings time for a minor update. I went to Sydney powercruise in feb and had a ball for a few laps until my wastegate started jamming open leaving me wi
  • All is good. I went in knowing it was a bit of a gamble for me and also feel the mamba compressor housing and chra are good, solid units.    I am still pretty pumped about how it's all comin
Posted Images
#2
Aren't they rated to 650hp? Cant see that rating being on 98.
GTX3582, PT6235 would do it. Would be more like $2500 though.
#3
Yeah I've used mambas gear alot and I rate it highly, that's a t04z coldside so you will loose some spool but is a 500kw e85 turbo.
Have you replaced the factory oil line?
#4
  • Author
Yeah the factory oil line was replaced when it went in for all the work 20k.
what would spool up quicker: The mamba gtx 3584 or gtx3582r?
http://www.ebay.com.au/itm/MAMBA-Ball-Bearing-Billet-Turbo4-GTX3582R-GT3582R-w-A-R-82-T3-V-Band-/282059838589?hash=item41ac13947d:g:gt8AAOSwuhhXVTcx
#5
Theoretically the 82mm wheel should spool quicker than the 84mm wheel but the 84mm could flow more and price point not much comes close.
#6
  • Author
So the 3584 has a 3" inlet where as the 382 has a 4". What does this mean to performance and spool time?
#7
Should spool faster but can limit top end power.
#8
What dan said
That turbo is what most call a stage 3 high flow and still bolts on, however I believe you can PM him and they will do it in a .7 cover with a 4 inch inlet for all the horny turbo spool goodness
#9
stage 33 66mm wheel can go in a modded 3" housing or go for a .7 4" 66mm is 5mm oversize and is good for 500wkw if you want to rebuilt a standard turbo otherwise kinugawa/mamba are great value for money but might cost a little more in the end with mods to exhaust etc if you go a full turbo..
both good options
#10
Same turbo then aren't they?
Recently Browsing 0
