MattyP MattyP Legacy Donating Member 6,317 Member For: 14y 5m 7d Gender: Male Location: Central Coast Posted 26/06/16 12:24 PM Posted 26/06/16 12:24 PM Plenty of good tunas Sydney side mate
SipposBFT Member 81 Member For: 17y 1m 20d Posted 26/06/16 10:56 PM Author Posted 26/06/16 10:56 PM Looks like F6 has stronger rods , but block is same... Still think spool or alike wud b the way to go ... Yeah tuners in syd are hit & miss from my experience... Seen sum guys get great results & then sum hav engine failures from the same stable... Gonna really research that area
gaz097 Legacy Donating Member 1,752 Member For: 15y 2m 20d Posted 26/06/16 11:10 PM Posted 26/06/16 11:10 PM The rods are the same between xr and f6, been the same from 06/06. The Fg f6 has different pistons. Same comp ratio just got a semi forged mahle I believe.
MattyP MattyP Legacy Donating Member 6,317 Member For: 14y 5m 7d Gender: Male Location: Central Coast Posted 27/06/16 01:04 AM Posted 27/06/16 01:04 AM That Wikipedia entry is all wrong
SipposBFT Member 81 Member For: 17y 1m 20d Posted 28/06/16 07:57 PM Author Posted 28/06/16 07:57 PM Head gaskets??
SipposBFT Member 81 Member For: 17y 1m 20d Posted 28/06/16 08:58 PM Author Posted 28/06/16 08:58 PM AND... I'm really getting annoyed with this friggin turbo-exhaust flange bolts which keep coming loose!!!! Tunehouse changed bolts to studs (with a gasket )but even they come loose & 1 has even fallen out !! .. don't want to change to a top mount manifold... Can I run an FG?
k31th less WHY; more WOT Site Developer 30,123 Member For: 18y 6m 1d Gender: Male Location: Melbourne Posted 28/06/16 11:36 PM Posted 28/06/16 11:36 PM You can use either stage8 fasteners or nordloc washers with new studs and they will stay on. No need to change the manifold type just to keep bolts in place. See here for the items: http://www.fordxr6turbo.com/forum/topic/44361-the-off-topic-thread/?do=findComment&comment=1557918 1
SipposBFT Member 81 Member For: 17y 1m 20d Posted 29/06/16 12:59 AM Author Posted 29/06/16 12:59 AM Thankyou kindly 1
Ralph Wiggum Moar Powar Babeh Legacy Donating Member 19,334 Member For: 21y 18d Gender: Male Location: Perth Posted 29/06/16 01:37 AM Posted 29/06/16 01:37 AM Nordloc's are the way to go, and don't be tempted to overtighten the studs as they will only strech once hot. If you want to fit a set of nordlocs let me know, My supplier will sell them indivually at excellent pricing. 2
SipposBFT Member 81 Member For: 17y 1m 20d Posted 29/06/16 05:19 AM Author Posted 29/06/16 05:19 AM Thankyou ralf... I will let you know 4 sure... But was under the impression FGs don't suffer from this... My mate worked @ peter warrens & said FGs didn't seem to suffer... Even tony from Tunehouse had the same opinion ... Let's hope this wks
