cuzzy New Member 12 Member For: 12y 2m 21d Gender: Male Location: Melbourne Posted 01/05/16 09:40 AM Posted 01/05/16 09:40 AM Hi all. I recently installed a walbro intake pump 400lph and new plastic fuel hoses. Also hi flowed the turbo. Do I have to replace the fuel pressure regulator as it's been tuned thou im having issues with the idle and stalling issues. Its very intermittent and revs drop under 500 if I come to a quick stop at the lights. I'm going back to look at the tune again never done this when it was at 300rwkw with stock fuel pump.
k31th less WHY; more WOT Site Developer 30,103 Member For: 18y 5m 12d Gender: Male Location: Melbourne Posted 01/05/16 10:07 AM Posted 01/05/16 10:07 AM Nope. Stock reg would be fine. Looking at the tune sounds like your best bet. Good luck in getting it sorted at the tuner.
bamk2f6tornado Legacy Donating Member 777 Member For: 12y 9m 19d Gender: Male Location: Rockhampton Qld Posted 01/05/16 10:10 AM Posted 01/05/16 10:10 AM You can have problems with high fuel pressure at idle with a walbro that large. As the reg physicaly can't return the fuel quick enough to maintain the 4bar base pressure and it will start to creep up and run rich. I had high fuel pressure issues in my Ute with that same pump and drilled out the standard reg. You can also buy a Bosch high flow unit fairly cheap. The stock return hole is quite small. stock vs Bosch high flow This is mine after I drilled it out. I didn't measure the drop in pressure but I noticed an immediate improvement in idle and so longer smelt rich.
cuzzy New Member 12 Member For: 12y 2m 21d Gender: Male Location: Melbourne Posted 01/05/16 10:25 AM Author Posted 01/05/16 10:25 AM Thanks for that info Bamk2f6tornado. I really think this fuel regulator is playing havoc as my tuner hasn't seen this issue before. I'll hunt around for a high pressure fuel reg Bosch type. I think only KPM sell them.. Correct me if I'm wrong.
Ralph Wiggum Moar Powar Babeh Legacy Donating Member 19,334 Member For: 20y 11m 30d Gender: Male Location: Perth Posted 01/05/16 10:41 AM Posted 01/05/16 10:41 AM Credit to ihatetoads for the side buy side pic.he sent it to me and I sent it to Alex. 2
gaz097 Legacy Donating Member 1,752 Member For: 15y 2m 1d Posted 01/05/16 12:04 PM Posted 01/05/16 12:04 PM Fairly certain I put a 1/8th drill in my turbo smart return port.
cuzzy New Member 12 Member For: 12y 2m 21d Gender: Male Location: Melbourne Posted 02/05/16 11:31 AM Author Posted 02/05/16 11:31 AM I purchased a high flow fuel regulator from Herrod today. Fitted it up still has fueling issues but yet to recheck the tune. This will happen this week.
sm13f6 Member 34 Member For: 11y 6m 7d Posted 26/07/17 09:03 PM Posted 26/07/17 09:03 PM On 5/1/2016 at 8:10 PM, bamk2f6tornado said: You can have problems with high fuel pressure at idle with a walbro that large. As the reg physicaly can't return the fuel quick enough to maintain the 4bar base pressure and it will start to creep up and run rich. I had high fuel pressure issues in my Ute with that same pump and drilled out the standard reg. You can also buy a Bosch high flow unit fairly cheap. The stock return hole is quite small. stock vs Bosch high flow This is mine after I drilled it out. I didn't measure the drop in pressure but I noticed an immediate improvement in idle and so longer smelt rich. do you happen to know the part number for the bosch high flow unit mate ?
bamk2f6tornado Legacy Donating Member 777 Member For: 12y 9m 19d Gender: Male Location: Rockhampton Qld Posted 26/07/17 09:23 PM Posted 26/07/17 09:23 PM Not a bloody clue mate
sm13f6 Member 34 Member For: 11y 6m 7d Posted 26/07/17 09:28 PM Posted 26/07/17 09:28 PM haha all good mate cheers
