  • New Member
  • Member For: 12y 9m 6d
Posted
Hi
my car is a ba 385kw on 19psi
its time for me to replace my valve springs. they are really soft. Anyway I was wanting to change my head gasket too. Considering that I have to remove the head I thought I would change the cams to something a bit larger. I dont drive the car alot so fuel consumption isnt a worry. I found a set of crow cams off ebay. Though I didnt really know what type until I sent the number on each cam to crow. it turns out they are as follows.
241/241    .530/.530 lift  112L/C
I know I would need vernier gears but I want to know would these cams require any other modifications to the head..? I havent seen a cam with this much lift for the dohc prior to this so im not sure. I know I will need a tune and the tuner will despise me for getting the vernier gears but they didnt cost that much and I dont drive the car much. Like mentioned I thought I would change them out now instead of later. let me know your opinions. cheers.
  • Legacy Donating Member
  • Member For: 12y 9m 25d
Posted
Cams are pretty much a waste of money unless your running a lot more power than yours. Money can be lots better spent elsewere
  • Member For: 13y 11m 22d
Posted
Heaps of people blow $800-$1000 on a turbo side intake and battery relocation cause they want that hectic turbo noise, not because it's necessary at their current power level. Y cant a man spend $800 on a tuff sounding cam too, specially since he's already there. I wanna do a cam with the valve springs as part of my stage 2 but no one seems to talk about it.
  • Member For: 18y 10m 7d
Posted
Because your car can become a pig to drive
Cams are for V8's
Just wind the boost up, remove some mufflers if you want cool sounds
Maybe even Put a few drops of water down each plug hole on #2 & #5...
It Will sound like you have a cam then [emoji106]
Posted
Cams are for V8's
  • The Toxic Rocket
  • Member For: 16y 5m 4d
Posted
I don't know of anyone personally that has used crows cams, however, I know plenty that use TBRE and Atomic, both sound unreal and regardless of power gains, sounds leaps and bounds better than taking a muffler out LOL
  • Like 3
  • New Member
Posted
I dont care for the sound. Nor do I care if the car is a pain to drive. this is not an everyday car so it doesnt bother mme. I need to remove the head anyway and I have the cams ready to go. From reading a few threads I concluded that some good gains are attainable if changing cams but my only concern was if there was any issue with installing a cam with that much lift. Was there any more work needed to be done to the head.
  • Dropping a turd
  • Member For: 18y 11m 1d
Posted
I gather you are doing valve springs
