rabbzh New Member 8 Member For: 10y 9m 18d Posted 30/12/15 11:55 AM Posted 30/12/15 11:55 AM Hi iv got a mk1 xr6t and im wanting to put the mk2 front end on does anyone no if headlights and bumper will bolt straight on and if any wiring is involved with headlightSent from my SM-G920I using Tapatalk 1
boost26 Member 51 Member For: 19y 5m 7d Gender: Male Location: Melbourne Posted 31/12/15 01:21 AM Posted 31/12/15 01:21 AM Most of it bolts straight on.Headlight wiring for low beam is different. You will need to do some wiring changes as Mk1 uses a H4 which has a dual element globe with low and high. Mk2 only has single element globe
rabbzh New Member 8 Member For: 10y 9m 18d Posted 10/01/16 10:58 AM Author Posted 10/01/16 10:58 AM Ok thanksSent from my SM-G920I using Tapatalk
Phillip vellios New Member 1 Member For: 10y 1m 13d Posted 28/08/16 02:36 AM Posted 28/08/16 02:36 AM On 30 December 2015 at 10:55 PM, rabbzh said: Hi iv got a mk1 xr6t and im wanting to put the mk2 front end on does anyone no if headlights and bumper will bolt straight on and if any wiring is involved with headlight Sent from my SM-G920I using Tapatalk Hi mate I WHANT to do the same eny devise
SgtPepperoni New Member 8 Member For: 8y 6m Posted 08/04/18 10:24 AM Posted 08/04/18 10:24 AM Hi there, I had a little accident and I needed 2 new FG XR6 MK1 headlights. I wanted to upgrade this to MK2 and reading this post I should do a proper wiring for them. Someone has done this job already? Any scheme of the wiring? Any suggestion? Any guide? Thanks :D
Rab WOT? Legacy Donating Member 10,981 Member For: 13y 7m 13d Gender: Male Location: Frankston, 3199 Posted 08/04/18 11:17 AM Posted 08/04/18 11:17 AM I think the bumper is a different shape WRT the headlights?
k31th less WHY; more WOT Site Developer 30,121 Member For: 18y 5m 28d Gender: Male Location: Melbourne Posted 08/04/18 11:24 AM Posted 08/04/18 11:24 AM the only different shape (on the outside) is the low beam globe mount at the back (unless you mean XR vs FPV, as XR has the twin curves at the bottom, FPV is flat). The wiring (for only the low beam) is probably just a matter of getting or making a connector(s) for the pins of the new globe type and removing the old connector and then joining just the pos/neg of the wiring as you don't need the relay portion anymore.
bossmang FREAKY Legacy Donating Member 12,441 Member For: 16y 9m 13d Gender: Male Location: Melbourne Posted 08/04/18 11:24 AM Posted 08/04/18 11:24 AM I dont think the bumpers are different should be straight swap but there is some wiring needed or a resister or some mumbo jumbo wizz bang thingo needed.
SgtPepperoni New Member 8 Member For: 8y 6m Posted 15/04/18 03:10 PM Posted 15/04/18 03:10 PM Who can do this job?
OZYWALKER XR50T Legacy Donating Member 2,795 Member For: 13y 5m 7d Gender: Male Location: Western Sydney Posted 15/04/18 08:07 PM Posted 15/04/18 08:07 PM Pm sent.
