JETURBO ...JD TUNING ADELAIDE... Legacy Donating Member 23,708 Member For: 18y 3m 24d Gender: Male Location: Adelaide Posted 20/10/15 01:33 AM Posted 20/10/15 01:33 AM Ull have to pull the cover then mate
Ralph Wiggum Moar Powar Babeh Legacy Donating Member 19,334 Member For: 21y 1d Gender: Male Location: Perth Posted 20/10/15 02:02 AM Posted 20/10/15 02:02 AM ^Whs. Best way. Lost lift method is too complicated. I got super lucky last one I did...less the 3 turns.
knowhereman Legacy Donating Member 107 Member For: 14y 11m 28d Gender: Male Location: Torquay, Vic Posted 20/10/15 02:11 AM Author Posted 20/10/15 02:11 AM FARK!!!
knowhereman Legacy Donating Member 107 Member For: 14y 11m 28d Gender: Male Location: Torquay, Vic Posted 20/10/15 02:54 AM Author Posted 20/10/15 02:54 AM The manual says sump off. Do I really have to take sumpOff to get front cover off?
Ralph Wiggum Moar Powar Babeh Legacy Donating Member 19,334 Member For: 21y 1d Gender: Male Location: Perth Posted 20/10/15 03:53 AM Posted 20/10/15 03:53 AM No,its tight but you can remove the two bolts from the sump to the timing cover and gently walk the cover off. But you need a new u seal for the sump and you probably need a puller for the balancer
knowhereman Legacy Donating Member 107 Member For: 14y 11m 28d Gender: Male Location: Torquay, Vic Posted 20/10/15 09:30 PM Author Posted 20/10/15 09:30 PM ok, if I am going to do this, then what else should I replace while I am it. Car is a 2004 XR6T MKII, 98,000km
JETURBO ...JD TUNING ADELAIDE... Legacy Donating Member 23,708 Member For: 18y 3m 24d Gender: Male Location: Adelaide Posted 20/10/15 09:36 PM Posted 20/10/15 09:36 PM Timing chain guides if your already there Got some spare coin, go oil pump gears 2
knowhereman Legacy Donating Member 107 Member For: 14y 11m 28d Gender: Male Location: Torquay, Vic Posted 22/10/15 06:13 AM Author Posted 22/10/15 06:13 AM Ok got the puller for the balancer How do you go about pressing the balancer back on? Cant hit it on and I was told not to use the bolt to drive it on.
JETURBO ...JD TUNING ADELAIDE... Legacy Donating Member 23,708 Member For: 18y 3m 24d Gender: Male Location: Adelaide Posted 22/10/15 06:16 AM Posted 22/10/15 06:16 AM Clean the spindle splines really well and clean the balancer as well then use some inox spray Lightly tap it with a rubber mallet and it will go all the way home with ease if the parts are well cleaned and lubricated The bolt might take up the last mm or two no stress
Ralph Wiggum Moar Powar Babeh Legacy Donating Member 19,334 Member For: 21y 1d Gender: Male Location: Perth Posted 22/10/15 06:39 AM Posted 22/10/15 06:39 AM Why wouldn't you use the bolt to pull it home? 1
