  • Member For: 12y 1m 17d
Take a good pic of your car somewhere nice and post it up so we can be jealous of having a T outside this country!!
^^^WHS
If you want max flutter. Remove bov and block holes. Then buy a turbo side air intake kit. Buy a good brand name one like Plazmaman, Process West, Nizpro and maybe one of them will be able to post it to you in Fiji?
If BA/BF..I think you can buy a under battery pod kit; otherwise may have to buy turbo side + battery relocation kit
Good luck!
Edited by PTR_NITRO_FG
  • Member For: 11y 2m 10d
STAGE 2; the flutter experiment !
Because just blocking off the BOV vacuum line was a big fail, I decided to follow Ralphs, Barnz and Nitros method of blocking all 3 lines leading to the BOV.
I found it easier to just remove the whole crossover manifold .
I made up a couple of rubber bungs for the inlet and outlet BOV hoses.
Result......
Flutter, flutter, everywhere !
Flutter mid throttle after changing gears,
Flutter backing off,
Flutter full throttle after changing gears,
And the turbo sounds a little louder maybe at full throttle.
It's not outrageously loud, but loud enough.
But is there a performance gain?
That is the big question isn't it!
I gotta say it feels a little stronger but I can't be 100% sure on that one.
I'll leave the bungs in a few weeks and watch my fuel economy and rear of car for soot.
Then I'll change it back and see if I feel any difference.
Disclaimer ; while I had my piping off I checked the turbo for play and it has more than I'd like!
So if it sh!ts itself then it could be due for a rebuild.
Edited by "Captain Retard"
  • Moar Powar Babeh
  • Member For: 19y 9m 19d
annnnnnnnnnnnnnnnnnd then?
  • Member For: 11y 7m 22d
It is actually marginally quicker in a circuit or drag situation. Particularly in a manual, less loss of boost on a change or even a 1-2psi spike. There is a reason WRC cars dont run them...
  • Member For: 17y 7m 18d
Maybe I should give blocking mine up a go. Might make me use less go pedal to get the noise and save fuel. I suspect I'd get tired of flutter even at moderate throttle lift off though. When you're passing that cop car you do not want to sound off!
