Peppy_t92 Silver Donating Members 748 Member For: 11y 26d Gender: Male Location: Liverpool Posted 13/08/14 07:14 AM Author Share Posted 13/08/14 07:14 AM Ahh I think the day has come!! last night I noticed a "whirr" coming from the front/mid section of the car, sort of like if the power steering pump is low on oil, checked it out, that was fine, and just left it at that..This morning going to work the noise had multiplied greatly, this started to worry me, no knocks, bangs, ticks, just a "whirr" it follows the rpm and it is more predominant under load in gear. Not so much in neutral... I thought the box might be low on fluid, so checked that this afternoon as per ZF's guide, the level was fine and I didn't notice any metal in the little fuild that trickled out... So what exactly could it be? Input shaft? Pump? Converter? Link to comment Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 11y 26d Gender: Male Location: Liverpool Posted 13/08/14 08:01 AM Author Share Posted 13/08/14 08:01 AM Actually it's more when it changes gears, like you can hear the solenoids/clutches slowly engaging the next gear... Very strange Link to comment Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 11y 11m 24d Gender: Male Location: Central Coast Posted 13/08/14 08:13 AM Share Posted 13/08/14 08:13 AM Rebuild time? Link to comment Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 11y 26d Gender: Male Location: Liverpool Posted 13/08/14 10:52 PM Author Share Posted 13/08/14 10:52 PM Yea I think so Matty, it's starting to slip before it grabs any gears, so safe to say it's gone..On a brighter note, I think it's time to take the engine out to freshen up and decide on some cams!!Unfortunatly it will be a few moth process, but hopefully it will come out better then ever 1 Link to comment Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 11y 11m 24d Gender: Male Location: Central Coast Posted 14/08/14 12:25 AM Share Posted 14/08/14 12:25 AM I hope so too Are you doing the rebuild? I'm asking because I need one as well and we could both have a crack at it Link to comment Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 11y 26d Gender: Male Location: Liverpool Posted 14/08/14 12:38 AM Author Share Posted 14/08/14 12:38 AM I'm going to do some research, see what it can find out, I know it has been done before, just have to ask the right people the right questions I guess, but it will be a long and slow process Link to comment Share on other sites More sharing options...
rednose RNS10S Donating Members 2,229 Member For: 17y 8m 12d Gender: Male Posted 14/08/14 02:32 AM Share Posted 14/08/14 02:32 AM Did you adjust any zf settings in HP tuners? Link to comment Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 11y 26d Gender: Male Location: Liverpool Posted 14/08/14 02:38 AM Author Share Posted 14/08/14 02:38 AM No. to be honest it hasn't felt healthy for a while, I'd feel better about putting it to the side for abit and doing everything properly Link to comment Share on other sites More sharing options...
JVK Silver Donating Members 751 Member For: 18y 4m 11d Gender: Male Location: North West Hot Hell,VIC Posted 14/08/14 10:44 AM Share Posted 14/08/14 10:44 AM Probabley clutches or clutch packs more so than anything else Peppy. 1 Link to comment Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 11y 26d Gender: Male Location: Liverpool Posted 28/10/14 10:42 AM Author Share Posted 28/10/14 10:42 AM Bit if an update.. The engine and box are out of the car, I borrowed a mates hoist for the box which made it incredibly easy, then took the engine out once I made some room at home, it's all just sitting there for now until I have saved a sufficient amount to give it a big hit without having to stop mid way and risk any seals drying up or anything like that..The plan is to max out my gtx3582, so around 500rwkw.. I'm still doing my research and I'm open to advice, but at this stage I'm looking at,-Manley "H" beam Rods 7/16 arp bolts rated at 1000hp-Manley Forged Pistons, smaller dish for 9.0:1 comp and bigger valve reliefs to suit oversize valves-billet oil pump gears (spool?)-girdle? Standard?-cosmetic mls gasket, will decide a thickness once headwork and cam are selected-I will port the head myself, they flow very well already but small gains are achievable in the right areas-oversize valves-cams will be decided once I know the head flow figures, I want to retain the VCT-anti-pump up or solid lifters-crow race springs-FG intake manifold-ceramic coating of the chambers, valves, piston tops, exhaust ports, (exhaust manifold, turbo housing and dump already done)-all the usuals like head studs, main studs, king bearingsFor the box Id just like it to handle the power for now, so a billet input shaft and excedy clutches seem to be all they need, as well as a healthy 3k stall, tce can modify one or Circle D make billet ones, not sure if I'm going to take it on myself or get a hand with it, we'll see.I'm aiming to get it all ready for Sydney Powercruise so mid March all the bugs need to be sorted and ready to let loose =)..Any helpful info is always welcome, thanks for reading, Joe 4 Link to comment Share on other sites More sharing options...
