luke187 Member 297 Member For: 11y 7m 12d Posted 22/01/15 12:20 PM Share Posted 22/01/15 12:20 PM I have the same issue with the boost gauge not reading right. Have the turbo boost gauge selected but just with the ignition on its reading -12psi so when im under power im just cracking 0psi with 50inches of vacuum at idle lol. I couldnt see anywhere that you could just adjust the gauge so im guessing its somwhere in the formula? Link to comment https://www.fordxr6turbo.com/forum/topic/88462-android-app-torque-tips-and-tricks/page/20/#findComment-1525386 Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 7m 28d Gender: Male Location: Brisbane Posted 22/01/15 12:41 PM Share Posted 22/01/15 12:41 PM Link to comment https://www.fordxr6turbo.com/forum/topic/88462-android-app-torque-tips-and-tricks/page/20/#findComment-1525390 Share on other sites More sharing options...
luke187 Member 297 Member For: 11y 7m 12d Posted 23/01/15 01:15 AM Share Posted 23/01/15 01:15 AM that's exactly what I have Link to comment https://www.fordxr6turbo.com/forum/topic/88462-android-app-torque-tips-and-tricks/page/20/#findComment-1525433 Share on other sites More sharing options...
luke187 Member 297 Member For: 11y 7m 12d Posted 23/01/15 01:47 AM Share Posted 23/01/15 01:47 AM Turns out I set the boost offset in the profile lol. Was thinking it said how much boost is the car running rather than a boost offset. All good Link to comment https://www.fordxr6turbo.com/forum/topic/88462-android-app-torque-tips-and-tricks/page/20/#findComment-1525447 Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 7m 28d Gender: Male Location: Brisbane Posted 23/01/15 01:57 AM Share Posted 23/01/15 01:57 AM Lol yeah unless your way above sea level no need to change it Link to comment https://www.fordxr6turbo.com/forum/topic/88462-android-app-torque-tips-and-tricks/page/20/#findComment-1525449 Share on other sites More sharing options...
raz1911 Member 110 Member For: 12y 2m 4d Gender: Male Posted 28/01/15 07:48 AM Share Posted 28/01/15 07:48 AM (edited) Has anyone tried Dashcommand? Its the same as torque pro but for iOS.Scrap that should of searched lolDo you have to do the equations on dashcommand? Edited 28/01/15 07:50 AM by raz1911 Link to comment https://www.fordxr6turbo.com/forum/topic/88462-android-app-torque-tips-and-tricks/page/20/#findComment-1526340 Share on other sites More sharing options...
Bulletime Donating Members 937 Member For: 14y 6m 9d Gender: Male Posted 28/01/15 09:51 AM Share Posted 28/01/15 09:51 AM Nah, don't do equations, I haven't run it for ages and it's had heaps of updates, lately they reckoned it might have now get oil and trans temp which I haven't gotten around checking Link to comment https://www.fordxr6turbo.com/forum/topic/88462-android-app-torque-tips-and-tricks/page/20/#findComment-1526367 Share on other sites More sharing options...
browned New Member 23 Member For: 10y 11m 9d Gender: Male Location: Hamilton, New Zealand Posted 12/02/15 07:47 PM Share Posted 12/02/15 07:47 PM Well got my OBDLink MX Wifi and thin extension cable early this week. Everything is setup and running and I am happy. But, are we really sure about the oil temperatures. Using the equation (((A*256)+B)*5)/74-16 I got the oil up to 84.6 degrees this morning. Starting at 23 degrees in the garage (which is about right). Driving a short trip to school, then longer to work about 20 minutes driving in total.But from reading around it seems that normal engine oil operating temperature should about 7 - 10 degrees higher than the water coolant which reached 90 degrees this morning. What temps are people getting on longer driver or at the race track? Link to comment https://www.fordxr6turbo.com/forum/topic/88462-android-app-torque-tips-and-tricks/page/20/#findComment-1529770 Share on other sites More sharing options...
f-wolf Member 897 Member For: 18y 2m 23d Gender: Male Location: ACT Posted 13/02/15 01:50 AM Share Posted 13/02/15 01:50 AM Re, " But from reading around it seems that normal engine oil operating temperature should about 7 - 10 degrees higher than the water coolant which reached 90 degrees this morning. " Your car got an Engine Oil Cooler that is part of your Engine Cooling System. My Car BA MK2 Turbo 6 Speed Manual got an after-market Engine Oil-Cooler that uses Air going through it to cool the Oil ! When starting from "Cold" the Water-Temp will only take a few Km's to get up to ' Normal ' Temp. Oil Temp will take some extra Km's to get up to > 80 C .The Engine Oil-Cooler System ( My Car ) comes with its own build-in thermostat that opens at around 80C to direct Engine Oil via the Oil-Cooler.What I have seen via the Oil Temp Gauge is this... When its cold weather and I drive on the Highway the Oil Temp will go down to about 75C and stay there !The reason must be the cold air going past the Engine-Sump.In warmer / hotter weather Oil Temp will go up to 80-85C and stay there. If I start giving the Car a hard time going up some steep Mountain Road the Oil temp will go to 100-115 C ... but will go back down to what I call " normal " once I get back to normal road conditions. Link to comment https://www.fordxr6turbo.com/forum/topic/88462-android-app-torque-tips-and-tricks/page/20/#findComment-1529872 Share on other sites More sharing options...
browned New Member 23 Member For: 10y 11m 9d Gender: Male Location: Hamilton, New Zealand Posted 13/02/15 02:20 AM Share Posted 13/02/15 02:20 AM I haven't fitted an oil cooler, car is stock. Does it come with one stock? if not my question still stands as to what other people are seeing on long drives and/or around the track.thanks Link to comment https://www.fordxr6turbo.com/forum/topic/88462-android-app-torque-tips-and-tricks/page/20/#findComment-1529875 Share on other sites More sharing options...
