  • Bronze Donating Members
  • Member For: 11y 5m 4d
Hi guys done a diff and transmission oil change today and thought I'd have a crack installing the earls turbo oil feed line.
I have read all the threads on this but everyone seems to have a lot more room than iv got Lol. Tried from the top and took the air box and piping out and can't even fit my hands down there. Figured I'd try from below and take the oil filter out but what I think is a sandwich plate is in the way. Car is a Ba Tornado. Any pointers? Or should I just let my tuner do it
http://i59.tinypic.com/23rll4m.jpg
Won't let me upload Pics.
Also what is the black plug that hasn't got anything plugged into it. Where is that meant to go?
https://www.fordxr6turbo.com/forum/topic/87659-turbo-oil-feed-and-loose-plug/
  • Member For: 14y 3m 29d
Hey mate dunno what that plug is, someone will chime in, prob should be plugged into something though...
On my fg it was pretty tight but I managed to get it all undone with the air box out, I just removed the filter, no earls, but it took me a few attempts because I didn't have the right tools at first. But I didn't have much room n my socket to tighten it up back into the engine block, I barely had one click on my socket worth of room, ended up with bruises up my forearms being all wedged in and pushing so hard lol.
Looks like the BA f6 has the oil radiator cooler thing on it which is good for cooling but yeah would probably make it harder from underneath.
Good luck it's doable so give it a go, otherwise if your not confident no harm getting the tuner to do it.
  • Member For: 11y 5m 17d
Did it on my fg fairly easily, a decent socket set with unis and a deep 22mm socket(from memory) will get you out of trouble. The BA manifold is different but I still think from the top is the go, bottom just wasn't happening. And save yourself alot of stuffing around and just remove the coolant line off the turbo to give you the room to rotate the old oil line 90 degrees and slide it forward, or just cut it. Just make sure your new oil line came with everything before destroying the old. I just disconnected the coolant line, stuck my thumb on the inlet on the turbo it's going to spew out there, leave the factory adapter on the oil inlet when doing this, I unintentionally left it on and it almost certainly saved me from getting coolant in the bearings. As for getting circlip pliers in the banjo bolt to remove the screen....just snap the clip with a screw driver and be sure to clean out any filings you may create. Bit of swearing and some brewskies will get er done ;-)
Sent from my C6903 using Tapatalk
  • 2 weeks later...
  • Member For: 20y 3m 22d
Being a tornado (fpv) it will have a gauge sender unit in there, so a spanner is your only choice and as the other said it a slow process
Edited by will-82
Gave it a go today... Managed to get a spanner in there to get the sender off and a 24mm socket to take the banjo off. Old owner has taken the old screen out already. I put the first bit back into the block then washers and earls banjo thing. Now when I went to tighten the adaptor that goes from the banjo to the sender unit. And iv given it a tweak to tighten it and have snapped the threaded part just after the holes for the banjo. Plenty pissed off words could be heard from the end of the street lol.
Having trouble uploading pics but does anyone no how much the new block fitting thing will set me back? Im guessing genuine is the only option
  • Member For: 15y 3m 20d
If you take the adapter out you should be able to removed the snapped part from it and just get another adapter.
  • Moar Powar Babeh
  • Member For: 19y 7m 14d
Aprox $70 from Fraud seems to be the norm. BF onwards have a different Design that prevents the breakage you have suffered.
The old design had the groove cut for the filter circlip inside the threaded portion so the force from tightening the fitting tended to snap the fitting.
Pic of part number attached
post-7403-0-11529000-1395018751_thumb.jp
Thanks Ralph. Is that an updated bf one or a direct replacement for my ba? Will the bf one fit a ba f6?
  • Moar Powar Babeh
The Sy part number suggests it a territory part, to the best of my knowledge the parts are backwards compatible.
