  • Dropping a turd
  • Legacy Donating Member
  • Member For: 18y 11m 3d
Posted (edited)
Give the actuator to the the guys doing the turbo. They will set the length.
Dont forget to take out the STD turbo oil filter.
Should throw in a Walbro intank GS294 fuel pump.
Edited by arronm
  • Member For: 13y 3m 28d
Posted
I will order the whole drop in tank setup with a walbro pump now that I read the how to fit pump thread on here, because it's a ute I will be drilling some of the spot welds to get to the tank and then re-riveting them. I can get the portingand larger flapper done by a place called Hyper gear for about 280-300 with postage including removong the exhaust housing, does that sound like a good idea or are there better places to get the turbo ported.
  • Dropping a turd
Posted
The shape of the porting on the housing is critical. I dont know pricing or anything about that company you suggested. Others may be able to help.
I only deal with Simon from XFT in Perth and Simon from Nizpro in Melbourne. These places are far from you, BUT, I can vouch for their work.
DO IT ONCE, DO IT RIGHT.
  • Moderating Team
  • Member For: 23y 7m 30d
Posted
^^^^^^ this guy ^^^^^^^
You remembered to do this bit? Or will remember?
Posted
Got a qoute from Simon from NIZPRO today ao port turbo housing and fit new actuato(changeover)r, $780 excluding freight. I think I will try hyper gear as their prices are in my league at the moment. I'm sure NIZPRO are really good but I can't justify nearly $900 to port the turbo including freight.
  • Hench, but no longer shredded or tanned.
  • Member For: 19y 6m 2d
Posted
You wouldn't like Simon @ XFT's prices then aha..
I got an exchange rear housing from Rapidsystems for 350$ (Ported/larger flapper), had to pay an extra 150$ deposit for his housing, but I'll get it back once I send mine.
  • Dropping a turd
Posted
As I said I am not sure about prices BUT if a port job is cheap but not done correctly, then its money wasted. Call Simon at XFT 92508266.
I think he charges $850 with the turbo on the car, so should be a bit cheaper, seeing as yours is off.
