  • Legacy Donating Member
  • Member For: 21y 4m 22d
Posted
Guys,
Apart from misfiring, are there any other symptoms which might indicate that the coil packs need to be changed?
For instance if the car feels like its lost a bit of power, and feels a bit sluggish, could that be an indicator of old and worn coil packs.
The car is a BF XR6T which has just hit 200K, and I'm noticing that its feels a bit sluggish both off boost, and on boost.
Seems like more effort is required to get moving rapidly...
Have changed plugs, changed petrol filter, and regularly lube the boost solenoid, and boost does peak at around 5psi.
Am I wasting my time and money by changing the coil packs if there is no misfiring?
Could it even be a partially blocked cat?
Any input is appreciated.
  • Member For: 15y 5m 16d
Posted
Stock cat?
In before Ratter says take it to a mechanic instead of throwing money aimlessly at it.
  • ...JD TUNING ADELAIDE...
  • Member For: 18y 4m 10d
Posted
LoL
Posted
Lol...stock everything!!! BOG STOCK STANDARD...(Oh apart from the air to oil tranny cooler).
200K on the odometer
  • Member For: 16y 8m 23d
Posted
Coil packs breaking down will typically show under load. Say 4th gear overtaking, put foot down and car becomes sluggish, but probably react normally when lower rpm unless they are really stuffed.
Posted
Guys,
It seems that the reason for the sluggish performance was my petrol filter.
Since my old man drives the car and barely goes over 1.5K revs cruising the suburbs he really didn't feel the difference, after changing it.
I drove the car on the weekend and it feels like a different car...its no slug any more...
I have previously changed the petrol filter once before, but for some reason this time it made a big difference.
Now I'm thinking this might be the reason my car has pinged once or twice...
Out of curiosity would a clogged filter lead to a lean condition, and trigger off the knock sensors, hence retarding the timing, and causing the car to drop power?
As the car feels much stronger now off boost, and on boost, even though its still making the same PSI as it was pre filter change.
  • Member For: 13y 5m 19d
Posted
I would believe so. Blocked filter means little fuel delivery and the rest of what you said will surely come.
  • Member For: 18y 2m 22d
Posted
Yep - I was getting pinging on my BF (stock apart from tune) until I changed the fuel filter. I cut it open and it didn't appear to be too bad but I didn't recognise the brand. Can't remember now but it wasn't ryco or motorcraft- anyhoo, filter changed, ping gone, me happy.
