  • Member For: 13y 11m 6d
Posted
Hi All,
I've recently had a TrueTrac fitted to my G6ET as the previous FPV GT LSD fitted developed a whine. When I picked the car up, the workshop indicated that the tailshaft was 15mm too long and was causing damage to both the gearbox and the diff due to lack of clearances. They also indicated that this was likely the reason for the original damage to the previous diff centre, and recommended that I source a new tailshaft asap to avoid further damage.
Rather than spend another $2k+ for a new tailshaft, on top of the $3.5k that the TrueTrac cost, is it feasible to get the existing tailshaft shortened? Vehicle is making approximately 300kw at the wheels with no immediate plans for any major increases, so a strengthened tailshaft seems rather overkill at the moment (especially as it could use a set of Brembos)
Any advice appreciated!
  • Replies 22
  • Menace
  • Legacy Donating Member
  • Member For: 15y 4m 30d
Posted
sorry I dont have an answer for ya but it sh*ts me how there is so many vartiations of tail shafts in the t's.. Good luck with it mate. 3.5k for a truetrac is a bit out there though.
  • Bored Member
  • Administrator
  • Member For: 23y 10m 6d
Posted
Seems odder that someone fitting a Diff doesn't recommend a shop to shorten it for you.
  • Member For: 15y 11m 1d
Posted
^Agreed. If it has never been changed then it can't be too long. Maybe get some pics or something and post it up and someone in the know might be able to verify that its a stock shaft?
Posted
Thanks for the replies guys.
The work was done at Elite, so I assumed that the info was pretty trustworthy. Apparently according to Steve/Paul this is a factory fault and a fairly common issue with the standard tailshafts?
3.5k too expensive? I thought it was pretty exxy, but it was drive-in, drive-out so I assumed it wasnt too bad considering parts/labour etc?
  • Member For: 17y 9m 12d
Posted
Where abouts do you live mate? im in CQ and have a stock shaft in the shed, get a pic up and some measurements of length and I will compare it with the one in my shed? if mine is shorter your welcome to come pick it up for a small price.
Posted
I believe they sublet the work to fit the TrueTrac to a diff shop, who recommended a new tailshaft. Apparently its only 15mm too long, so I'm wondering if theres another factor involved.
I'm in South East Brisbane. I'll try and get some pics and post them up here for reference.
I'm 99% sure that the current tailshaft is stock.
Posted (edited)
off to hardy splicer to get it shortened then...
Edited by Bonjaz
