  • Member For: 14y 11m 25d
Posted
Hey there,
Just wondering if anyone makes replacment cv's for the BF (ute) besides fraud! My center cv seems fine, I'll clean it up at work on monday and have a better look but the rear joint that bolts to the diff flange is totaly stuffed.
The rear cv looks like a sealed unit (I don't have a repair manual yet) does it need to be butchered to get it off or is there a way to dismantle them, though, it seems to be fairly f@#ked as was making a horrible noise/vibration.
I did get an over the phone quote from SDS (sydney driveline services) $1200 for a reco'ed unit and around the $1800 mark for a heavy duty 2 piece race spec type thing but if I can rebuild mine for a couple hundred dollars I'd rather go down that path for now. Are the cv units the same between sedan and ute? I know there's variations between the shafts.
Any help would be appreciated
Cheers Dan
  • Menace
  • Legacy Donating Member
  • Member For: 15y 5m 6d
Posted
I was quoted something like 400bux I think to just have the CV's replaced and then a rebalance using the existing tail shaft. Mines a sedan though but I think they both have the same amount of cv's anyway. Might have been abit more 100bux or so cant remember but yeh sub 600 foshaw.
  • Member For: 17y 6m 21d
Posted
Funny you mentioned this. I was looking at my tailshaft today wondering how you undo them. I tried the little 8mm bolts but they were too tight for their own good and rounded off...
Posted (edited)
I hear that, I'd like to know what the torque setting is for those 8mm bolts. I had a hell of a time getting them to crack.
Edited by RHR
Posted
I've got a 1mm disc that will fix their little red wagon...
  • Banned
  • Banned
  • Member For: 14y 2m 7d
Posted
3/8 breaker bar with reducer to 1/4" drive 8mm socket worked well for me the other week but I hear what your saying.
  • Member For: 19y 3m 2d
Posted
Mine came off with the spanner, have taken it off a few times now though.
  • Member For: 15y 1m 11d
Posted
Do yourself a favor and get a 6 sided socket they are alot less likely to round the head most socket are 12 sided which are good but if its that tight just pick one of those up should make it easier
Posted
found the problem, a rip in the boot and one very dry cv assembly that was a pain to get apart. Now, where to get a new cv from?
Posted
Were are you from?
GJ drivelines come highly recommended
