  • Member For: 17y 11m 5d
Posted
Harvo wat is hardy spicer unit? I no they do drive lines but Can please ezplane it a little better like what you got from them cheers
  • Member For: 15y 5d
Posted
Yeah mate, it was a complet cv assembly that came in a box with hardy spicer written on it. Comes with cv, front and rear covers, rubber boot clamp, gasket, circlip and grease. Everything you need to do the job except tools and degreaser.
I also cleaned, inspected and re-greased the center cv joint while it was appart. Probably a good idea to do this to both cv's if still in good condition, like anything the grease in there gets a hard time and should be replaced from time to time. Not sure if it's got a "do this at xxxkm" mine has 115000k's and the grease was looking pretty second hand compared to the new stuff.
Cheers
Posted
Cheers
are they standed parts or bigger or stronger ? . Thanks for the reply
Posted
Cheers
Posted
No worries mate, it was a standard replacment gj drivelines can supply a chromolly cv that's a cut and weld job for around the $750 mark if you need something alot stronger.
