  • Member For: 14y 4m 23d
To get a 5 sar rating, it must NOT be possible to turn off DSC, the exception being Police vehicles where they can opt to get a button put in. If it is possible, you lose points.
  • Member For: 17y 5m 18d
So you can turn off traction control with the 'burnout' button, but DSC will remain on regardless in case you are swerving or trying to take a corner too fast, is that right?
  • I Lead Not Follow...
  • Member For: 13y 22d
yeah that's right buds...
Take the fuse out
ive tried taking the fuse out and donuts...doesn't work!
  • ʎǝʞuoɯ ɹoıuǝs
  • Member For: 16y 4m 26d
bf didnt have a 5 star rating and I'm sure you can turn dsc off. the way it slides is different with it off, but with it on its not like regular traction control cutting power either.
  • Member For: 18y 11m 15d
Had a customer do a turbo conversion to his BA Ghia a while back, did it all as per ford turbo specs, he later decided to change it to ZF which meant he had to convert it all to BF spec, had a few niggling issues, one of them was the trans came from a Typhoon/Tornado and the rest of the gear came from a XR6T, some of the issues were brought about because apparantly the FPV's did not have DSC.
Yeah, taking the fuse out wont work. It has to be designed to be 'impossible'. The only thing that may work is if the tuner can disable it for you.
  • Member For: 15y 6m 17d
with the bf xr6t's the one switch turns them both off, light on the dash = hoops possible
