  • Member For: 17y 11m 6d
Posted
Can anyone advise me what is the recommended duration for changing transmission oil and filters for BF MK2 6 speed gearbox (automatic)
  • ʎǝʞuoɯ ɹoıuǝs
  • Legacy Donating Member
  • Member For: 17y 9m 6d
Posted
ford will tell you its sealed for life.
zf will tell you 160,000kms.
if you drive it hard, I'd change it sooner.
I changed mine ~ 40k I think.
  • loitering with intent
  • Member For: 23y 1m 3d
Posted
Changed mine 3 times.Done 75000kms use transmax Z
Posted
how much does it cost? By the way why ford is saying it is sealed for life....I call 2 ford dealers and both gave me different answers. One said its sealed for life and the other one said every 200000Ks............confused
  • Member For: 18y 4m 11d
Posted
Both zf & ford are probably about right if you drive ya car like a b!tch but if you drive it hard or its modified the more the better. I changed mine at 30K and it was pretty bad.
If its under warranty stick with what ever ford recommend if not change to transmax z & you'll never go back.
  • Member For: 21y 8m 11d
Posted
re. cost, I just had mine done, cost $380. cars done 65k, I've only had it for 15k's so more for peace of mind.
  • ...JD TUNING ADELAIDE...
  • Member For: 18y 3m 22d
Posted
buffa ya slapper whats transmax z worth for the job or whats a total cost to do ya service?
  • Member For: 17y 30d
Posted
But you need 9 Litres of Transmax if u're taking off the pan/gasket/filter, 4 litres if its just interval service.
I use Penrite SIN ATF, exactly the same one used in Bimmers, I think it works what does everybody here think?
  • Member For: 20y 9m 10d
Posted
If u're taking off the pan/gasket/filter it will take about 5 to 5.5 litres
9 litres is when trans and convertor are empty
My BF did 120,000 km with transmax z no problems factory trans
