  • Banned
  • Member For: 17y 2m 22d
Posted
Anyone know/able to get 205L drums of E85? And where can they be refilled? Proper e85 not the southland one or caltex bio-flex stuff...and costs?
  • THE PSYCHO XRT
  • Legacy Donating Member
  • Member For: 20y 10m 1d
  • Gender: Not Telling
Posted
Whats wrong with the e85 @ Southland? I have heard that fuel is just as good as the one suppied @ Hoppers crossing?
  • Sandtrap Motorsport
  • Member For: 17y 10m 14d
Posted
if you can, source E100 ... its cheaper, and mix it yourself with 98ron :)
  • Member For: 17y 4m 16d
Posted (edited)
just be aware that ethanol is hygroscopic (absorbs moisture) so if your going to buy in bulk keep it sealed or use it quick
Edited by possum
Posted
yep and store the drum on wood or a tyre. it cant be left on the ground as it absorbs water through the base
  • Member For: 18y 2m 24d
Posted
come 2 hoppers crossing if your not 2 far. its like 99c a liter. just curious would a surge tank and 1 pump be enough or do you need 2 pumps? cause im going a full e85 tune as well.
  • Banned
Posted
donno depends what the tuner tells me lol.
but I hear the e85 from southland clogs up systems. And my mate in his 7sec torana used it for a while till his fuel system was rawted.
Im sure people have tood and bad experiences.
If worse comss to worse, ill just rock up to southland with the barrel and fill it up. Ill see how we go.
  • Forged Member
  • Member For: 19y 8m 2d
Posted
Its not necessarily the supplier that is causing the clogs, it can be the effect ethanol has on tradition petrol filters and lines - you basically have to run alcohol filters and lines when running E85 and up. If your mate with the Torana was running a leaded fuel previously he may have still ran the same filters and destroyed them - just like what happened to 2MUCHHP from XFT
  • Banned
Posted
he works for efi spares and ran 7.91 @ 191mph, I think he knows what fuel lines he needed :P And its a corolla not a torana.
But yeah for our cars, might be different story as to what lines / filters etc need replacing
  • Member For: 20y 4m 12d
Posted
Senna is correct in what he says, our production cars in australia can not normally use E85 because of the damage it can do to the fuel system, this is changing as it becomes more popular, why do you think most manufacturers will only recommend E10.
