  • Replies 63
  • Member For: 18y 5m 9d
HI PSI
They look orsm
So how much where they and did you get a rear one.
Anyone want to buy a pair of near new genuine BF F6 grills so I can get these.
  • Member For: 16y 8m 15d
Is everyone a big fan of the honeycomb design if it could be done for a factory finish I can't see it would be that hard to make some up, I'll fire up the cad program when I fly home and have a look:)
And mainly the top one? I like my intercooler hanging out personally....
The only problem I've had when playing around with grille mesh bits was the airbag bar behind the badge, ended up just painting it matt black and it was ok
  • Member For: 19y 29d
HI PSI
They look orsm
I had previously purchased the Typhoon mesh with the FPV logo in it from ebay and I managed to get the details from the manufacturer from him... Hence the Fpv logo in it...
The top grille and the GT bottom mesh cost me around $300 delivered. I had the F6 emblem removed form the upper mesh as I do not own a Fpv. I did not get the rear as I alrady had genuine typhoon mesh here. Although, I may consider getting it later on...
I managed to fit the bar today and the Rapid cold side piping gave nothing but grief. No matter what I did I could not get the piping to sit far enough back to allow the fog lights to be fitted. I also had to remove the tray also...I ended up beaking two of the plastic clipss on my new bezels as a result..... GRRRRRR !!! NOT Happy !!!!!
Anway I have attached a new pic of the bar fitted.. I am looking for plastic top grille section if anyone has one for sale....
I will forward you his details if you like.....
Edited by HI PSI
  • Member For: 17y 7m 14d
"I managed to fit the bar today and the Rapid cold side piping gave nothing but grief. No matter what I did I could not get the piping to sit far enough back to allow the fog lights to be fitted. I also had to remove the tray also...I ended up beaking two of the plastic clipss on my new bezels as a result..... GRRRRRR !!! NOT Happy !!!!!"
Had a similar prob myself. The silicone joiners on mine were too long on the each end of the 45's, which meant it sat to far down.
The solution was to trim about 30mm off each end of the silicone 45's where they meet the alloy pipe bend. This allowed the pipe to be higher and FURTHER BACK without causing any distortion of the joiner under the headlight.
