Best Oils And Fluids For Turbo Motor And T56?
Featured Replies
#1
I will be servicing my ba on the weekend and was hoping you guys can help me out with some info
I was wanting to know what is the best grade and brands of oil for a ba turbo motor?
whats the best fluid to use for a t56?
what spark plus brand you guys prefer and what gaps?
thanks guys
#2
I can only help you with the engine oil because I just changed my. In the ford service manual they said to use a 15W - 40W. The first number you should try and kept the same but if your car is modify you should try and increase the second one.
There were a few oils to choose from I decided on the Nulon 15w - 50w full synthetic. If your car is stock you should stay with a 15W -40W.
#3
There should be a thread with what part and recommended oil.. Cause as we modify our cars, the standard lubes surely would need upgrading too..
Engine:
4 Speed:
6 Speed Auto:
5 Speed:
6 Speed manual:
Diff:
Power Steering:
I've probably missed some things but you get my drift...I know everyone has there own opinion as to whats better/what they use, but it'd be a a good start point for people that aren't sure... Could even go further, Coolant etc..
So someone with more knowledge than me feel free to fill in the list. Turbo ute, sorry to hijack but im sure you'll benefit too..
#4
Engine oil choice is a pretty personal thing. There are some good threads here if you do a search. My motto regarding motor oil is pick the one you are comfortable paying for and change it and the filter often. I use a Nulon synthetic in the right weight ( 10W-40 from memory) in my T and change it at 5000klm intervals. I personally feel that the intervals between changes it more important than the brand of oil.
For the T56, Mal Wood recommends Castrol Transmax Z, which is actually a synthetic Automatic transmission fluid. Its around $70 for 4ltrs from Supercheap or autobarnand and you need 4.8 or 4.9ltrs when you change it. Change it via the reverse sensor on the LHS of the box, not the plug on the right, which is too low to get enough fluid into the box. Fill it until the oil comes out of the hole you are filling it from.
Regarding plugs, I haven't changed from the OEM items, but if you have modded your car, gap them at 0.8mm. If not stay with the factory gap which I believe is 1.0mm. Check your owners manual to confirm the gap if standard as I am only going off memory.
#5
If your after brands..
Nulon full synthetic oil for motor (comes in a gold coloured 5 or 6 litre bottle) Was using another brand in my old BA then changed to the nulon. Instant change in engine sound. Kinda hard to explain but seemed smoother.
Also had the T56 and wan castrol tranzmax Z which is an auto transmission oil. Yeah sounds odd but its great stuff be it a bit pricey. Made the shift feel smoother and made the box a fair bit quieter as they have a tendancy to be a litle rattly at idle.
Now with the FG I run Nulon in the motor and Im yet to do a gear box oil change. Transmax will be going in it for sure.
#6
Nulon is very popular around here for the modded T's.
I personally use Nulon fully synthetic 10w-40 and like others have you cant miss it in the golden coloured bottle. I find a Large six litre bottle and a small one litre bottle does the trick (if changing oil filter s well) a little less if not doing filter.
#7
I usually use fuch oil, but couldn't get it so this time round I used valvoline 15w-40....working really well actually...
Replaced my spark plugs recently aswell and gapped them to .8mm...
Also consider changing your fuel filter and clean your boost solanoid valve and throttle body during your service as there tends to get a lot of gunk and crap, you will notice a difference if you've never cleaned your BSV.
#8
  • Author
thanks guys great help, I will b using Nulon fully synthetic 10w-40 and castrol tranzmax Z, one question, wheres the boost solanoid valve?
#9
RP oils FTW
#10
wheres the boost solenoid valve?
Just do a search mate - theres a good write up of exactly how to clean it out.
Mind you - ive done it twice and its never done any good for me... matter of fact it idled like a pig for half an hour before coming good.
Recently Browsing 0
