  • Moderating Team
  • Member For: 23y 8m 7d
Posted
Got BP back, 37rwkw's @ 19:1 AFR, nice huh. New box shifts nice but leaks oil & Goldie has screwed up me fuel pump delivery line ............ again
Scotty
<{POST_SNAPBACK}>
19:1 AFR?
You sure? :spoton:
  • FORD FORD FORD
  • Legacy Donating Member
  • Member For: 23y 6m 21d
Posted
Yes Micko, I'm 100% positive, 19:1 AFR & a resounding 37rwkw's, she pulls like a Focus
Scotty
  • Poison Fish. Poison Fish. TASTY FISH!!!
  • Member For: 23y 6m 23d
Posted
If I add Strawberry Jam (Aussie Golden Circle, of course :spoton: ) to Plain Yogurt, does it then become Strawberry Yoghurt :w00t2:
Posted
Scotty
37RWKW :w00t2:
Way to make me and 'Da Pinny' Jealous there Scotty :spoton:
  • Sucker
  • Moderating Team
  • Member For: 22y 5m 13d
Posted
<{POST_SNAPBACK}>
I would recommend doing it the other way around, add a small amount of the yoghurt to the jam and mix well first - then add the strawberry back into the remaining yoghurt and fold through. Then there will be no lumps lumpen.
I know I haven't answered your question, but it is the off topic thread you're in after all.
Trent.
  • F6+300+
  • Member For: 21y 11m
Posted
Am missing BP, hopefull get her in the morning, then get onto fixing the wastegate drama. Driving the wife's 152kw AU1 today, WOW
Scotty
<{POST_SNAPBACK}>
you poof.. give ol AU some credit..
AU engine specs..
4.0L Intech 6 cyl
Bore and stroke: 92 x 99 mm
Power: 157kW at 4900rpm
Torque: 357Nm at 3000rpm
Overhead camshaft, 2 valves per cylinder
Fuel system: EEC V fuel injection
Compression ratio: 9.6:1
5.0L V8
Bore and stroke: 102 x 76 mm
Power: 175kW at 4600rpm
Torque: 395Nm at 3200rpm
Pushrod overhead valve, 2 valves per cylinder
Compression ratio: 9.1:1
4.0L Intech VCT 6 cyl (Fairmont Ghia)
Power: 168kW at 5000rpm
Torque: 370Nm at 3500rpm
4.0L Intech 6 cyl (XR6)
Bore and stroke: 93 x 99 mm
Power: 164kW at 5000rpm
Torque: 366Nm at 3150rpm
4.0L Intech VCT 6 cyl (XR6 VCT)
Power: 172kW at 5000rpm
Torque: 374Nm at 3500rpm
5.0L V8 (XR8)
Power: 185kW at 5000rpm
Torque: 412Nm at 3500rpm
4.0L Intech Dedicated LPG 6 cyl (AUII/III)
Power: 143kW at 4500rpm
Torque: 362Nm at 2750rpm
5.0L V8 (AUII XR8 sedan until April 01; Ute, March 01-)
Power: 200kW at 5000rpm
Torque: 420Nm at 3750rpm
5.0L V8 (AUII/IIIXR8 sedan, May 01-)
Power: 220kW at 5250rpm
Torque: 435Nm at 4000rpm
Compression ratio: 9.4:1
5.0L V8 (AUII XR8 ute until Feb 01)
5.0L V8 (AUIII XR8 ute)
VT-VY commodores were the ones with 152kw engines... :w00t2:
:w00t2:
<{POST_SNAPBACK}>
Glen you forgot one AU>>>>
5.6L V8 AUIII T3
Bore and stroke: 101.67 x 86.36 mm
Power: 250kW at 5250rpm
Torque: 500Nm at 4250rpm
Fuel system: Sequential multipoint fuel injection
Maximum Speed: 252 km/h
0-100 km/h: 5.86 secs
Standing 400m: 14.18 secs (Motor 2002)
:spoton:
Posted
Trent.
BUUUUUUUT, that would take longer? Right?
Exactly... :spoton:
So, back to the original question? Mere Strawberry Yoghurt or
'Lumpy and Son's Neurolytic Restabiliser' - It's like there's a party in your mouth, and everyone but Glenn's invited 'Patent Pending
  • Sucker
  • Moderating Team
Posted
Trent.
<{POST_SNAPBACK}>
Exactly... :spoton:
<{POST_SNAPBACK}>
No mate - just strawberry yoghurt.
Like you could have a party without a pretty biatch like Glenn in attendance
Trent.
  • Moderating Team
Posted
Scotty
<{POST_SNAPBACK}>
Dunno whats going on here, and I am not doubting Ian's tuning ability one bit, but if my T was running 19:1 AFR id be a tad concerned! that's a bit too lean for my liking! :blink:
Please explain!
Correct me if I am wrong, I really hope ive stuffed something up, or else I better order you a new short engine on next week's Ford stock order..... :ermm:
Posted
Wouldn't the drop from 250+RWKW to errr...40 be a bigger pointer to Ol' Blackie commiting Seppuku?
