  • Legacy Donating Member
  • Member For: 22y 1m 6d
Posted
Ok untill we can remove the turbo and port the waste gate more the minimum we can get away with ATM is 398RWKW @ 15 - 16 psi slightly climbing as rpm increases. Might add a little boost at the start and round it up to a whole 400 just for the number crunchers.
Gee mate I really feel sorry for you with the minimum power you can get away with :bowdown: ..
Seriously though that is an awsum result and the writeup/pictures are very informative :spoton:
  • Replies 56
  • Member For: 22y 8m 3d
Posted
any further news???
when are we going to the track to run some numbers???????????
  • Member For: 20y 1m 3d
Posted
Great to see you got the wheel in motion James.
Does this mean you will be at Willowbank for test n tune this wednesday night!
Cheers Paul
  • Member For: 21y 20d
Posted
Inital runs were in the high 300 low 400 RWKW but boost was rising with zero waste gate command !!
These Plasmaman kits flow a lot of air, I think a external waste gate is most likely the go. Tried split dump and single 4 inch dump both from Xforce but the turbine gas flow was still too high there-for the turbo made more boost at the top end even though the waste-gate was open 100%.
After tuning vonn was able to run a nice 380ish RWKW tune on 15-16psi with a little timing removed, as the fuel supply is still to be sorted (Read not fitted yet).
Will post graphs later
  • Member For: 21y 5m 3d
Posted
Well done, awesome result. Amazing how much progress has been made with all the R&D gone into the right places.
Looking forward to the final results. Will have some unbelievable power.
  • Member For: 23y 3m 7d
Posted (edited)
FANTASTIC!
I'd hate to have to put up with a lazy 400RWKW. :laughing:
Edited by RAPHOON
  • Member For: 21y 1m 24d
Posted (edited)
Nice work
To give you a bit of idea.. When I removed my wog cooler, and switched to the nizpro cooler / plenum setup, I could NOT get any less than 17psi boost with 0 duty, and that was after I modified my wastegate the first time..
To control the boost, I had to put a cat back into the exhaust.. Then boost was setup to 15psi, with approx 70% duty at 5000rpm (12psi actuator)
After I removed my turbo the second time, re-ported it MORE, and contoured the port towards the flange of the turbo, opened it right up, really only leaving about 1-2mm of seat left, then put it on the car.. I put it all back together, and I found it peaked LESS boost than before. I had to re-tune it to give it MORE duty cycle than before to bring it back to 15psi..
Then I removed the cat, and crossed my fingers (please no more 17psi with 0 duty)..
And presto, it spiked to 17psi as it come on boost, and the beauty of using closed loop boost control, it stablised back to 15psi boost..
I then retuned it by lowering the duty cycle all over, especially at approx 3500rpm where boost comes on so it doesnt spike past 15psi
Beautiful.. Perfect 15psi boost control :)
EDIT: how much was it opened.. Like my original mistake? or right up leaving 1 to 2mm seat? with conturerd towards the flange... I have no regrets on how big I ported mine.. considering I already saw heat cracks with 3-4mm worth of seat, I though, its just gonna crack anyways at standard size..
Danny
Edited by Headsex
  • Formerly XR6NA
  • Member For: 20y 10m 4d
Posted
Wow they are some impressive figures. Enjoy :bangcomputer:
