  • Member For: 20y 7m 4d
Posted
This might be a really stupid question but my car is sitting in my garage and has been for the last 2 months, cause of some moron crashing into it but anywho. I was just wondering if disconnecting the battery from the car to stop it from draining it will do anything to the computer/electrics ?
Cheers,
Daniel
  • Moar Powar Babeh
  • Legacy Donating Member
  • Member For: 21y 18d
Posted
it wont do anything detrimental will just reset the "learned" portion of the tune. Remember negative off first and back on last... :spoton:
  • Just sit back and enjoy the ride...!
  • Member For: 23y 1m 17d
Posted
Yep, it's okay to do it. I disconnect my battery whenever I disappear overseas for more than two weeks. Once you reconnect the battery, leave the car alone for a minute or two while the car computer "boots up". Once you see the "Smart Lock" light flash by itself on the dash, then she's ready to rumble.
Not necessarily electrics-related but still very important... let the car idle for a few minutes in order to get the "juices flowing" inside the engine. After a few weeks of sitting still, all your engine oil will have pooled down in the sump. Let your T warm-up properly before driving off so that you get the oil lubricating your engine parts again.
:spoton:
Posted
Cheers lads, will do thanks for the advice.
Daniel :blink:
  • Member For: 20y 2m 26d
Posted
The problem I have is, when ever I try & disconect my battery, the factory car alarm goes off in my ear & nearly deafens me! :spit:
Does anyone know how to dissable it(I have tried the remotes already)?
Can anyone help me??? :pooh:
  • Member For: 22y 1m 2d
Posted
your alarm should have a "valet" button to turn it off temporarily
  • - Track Bound EVO III -
  • Member For: 21y 9m 25d
Posted
The problem I have is, when ever I try & disconect my battery, the factory car alarm goes off in my ear & nearly deafens me! :spoton:
Can anyone help me???  :nono:
Turn the car to the 'On' postiion. Then remove battery leads.
Goes against everything, but, it's how it's done..
  • Member For: 23y 6m 9d
Posted
The problem I have is, when ever I try & disconect my battery, the factory car alarm goes off in my ear & nearly deafens me! :yikes:
Can anyone help me???  :funnydance:
You need to turn the car to on and then between 1 and 3 seconds, remove the negative lead.
  • Member For: 20y 8m 5d
Posted
If you are disconnecting the battery to stop it going flat and you wish to give it a normal life then make sure you cycle it whilst it is sitting out of the car. Regular charging is good for prolonging battery life.
