mikeBF2TLS Member 32 Member For: 23y 1m 13d Gender: Male Location: Canberra Posted 05/10/06 10:54 AM Posted 05/10/06 10:54 AM Forum,Now that Im finally committed to my new T I have aquestion. I note that a lot of you guys change your oil in between (I assume) the standrd Ford services. If this is so do you:-1) use the same oil as Ford uses at time of their service or2) use what you think is best for the TIf its 2) 'cause you may be using different oil types in between will this effect the engine long term?Just curious as I also do not trust 15k's in between oil changes and want to know what the norm isCheersMike (ACT)
sinnkexr6t Member 291 Member For: 20y 2m 24d Gender: Male Location: Melbourne, Hampton Park Posted 05/10/06 11:09 AM Posted 05/10/06 11:09 AM (edited) Dont mean to be harsh or anything but theres like one million threads on this Try "search" option mate plenty info about oils and other stuff that you might be interested in. Heres couple regarding the oil http://www.fordxr6turbo.com/forum/index.ph...topic=28107&hl= http://www.fordxr6turbo.com/forum/index.ph...wtopic=28122&hl Edited 05/10/06 11:10 AM by sinnkexr6t
chooch Member 256 Member For: 22y 7m 19d Location: Adelaide Posted 05/10/06 12:00 PM Posted 05/10/06 12:00 PM I change the oil in between services and use full synthetic and the same brand always. I get Ford to deduct the cost of oil from the service and get them to use mine.So basically the oil gets changed every 7500km.
Jonno Member 79 Member For: 20y 1m 15d Posted 06/10/06 12:06 AM Posted 06/10/06 12:06 AM I used Castrol Edge 0W40 at 1500 kms in my 06 BF XR6T, and plan to change it each 7,500 kms. I supply the oil to Jubilee Ford.
MUZ580 Member 448 Member For: 20y 5m 25d Gender: Male Location: Manly - Sydney Posted 06/10/06 12:28 PM Posted 06/10/06 12:28 PM Heaps of threads on this but I use Mobil1 5w-50 every 7500kms 1
Mildman Member 149 Member For: 20y 10m 12d Posted 25/10/06 11:21 AM Posted 25/10/06 11:21 AM Just to open to oil can of worms some more - I emailed Castrol with the question of best running in oil and best oil to use post running in.The recommended GTX3 15W40 for running in - although the disclaimered it by saying they don't know what Ford's running in oil spec is. They said GTX3 as it was a true mineral oil. Magnatec was the 2nd recommendation as it is a semi-synthtetic 10W40.After run in the recommended the 10W60 Edge.I'm still of the view that 0W40 would be better for the turbs as it matches the operatring viscosity better....but will decide post running in what is better.
tmac450 Member 1,650 Member For: 20y 19d Gender: Male Location: NSW Posted 25/10/06 11:32 AM Posted 25/10/06 11:32 AM Every mechanic I've spoken to recomends not using fully synthetic oils in any engine until they get to 5,000ks an properly bed in. Synthetics can be too slipery and not alow enough wear for the bedding in process. This has also been backed up by the Australian importer of Royal Purple who only deals in synthetic oil.As far as changing early, a good synthetic will retain its properties longer and has a better chance of lasting longer (all depending on how hard you work the motor of course, I've left Royal Purple in for 20,000 in some cars and it comes out looking new).My oil change regeme and any car I have is:Dump the first oil at 1,500km to get rid of any swarf (metal fragments) in the motor, and replace it with a quality mineral oil.Change the mineral oil for a good synthetic at 5,000Change the first batch of synthetic at 15,000Then depending on the type of driving, and the car, replace the synthetic every 10 - 20,000ks.One thing is for sure though, I wouldn't trust the cheap, buy in bulk crap the dealers use for 15,000, especially the first 15,000.
JBomb3000 Legacy Donating Member 875 Member For: 20y 10m 3d Gender: Male Location: Victoria Posted 25/10/06 08:25 PM Posted 25/10/06 08:25 PM Just to open to oil can of worms some more - I emailed Castrol with the question of best running in oil and best oil to use post running in.The recommended GTX3 15W40 for running in - although the disclaimered it by saying they don't know what Ford's running in oil spec is. They said GTX3 as it was a true mineral oil. Magnatec was the 2nd recommendation as it is a semi-synthtetic 10W40.After run in the recommended the 10W60 Edge.I'm still of the view that 0W40 would be better for the turbs as it matches the operatring viscosity better....but will decide post running in what is better.←that's interesting, I also e-mailed castrol when I changed my oil at 3000 kms and asked them which edge variant would be most suitable for a stock T and they said the 0W-40. Depends on who answers your e-mail as to what the best oil is apparently
Mildman Member 149 Member For: 20y 10m 12d Posted 25/10/06 10:48 PM Posted 25/10/06 10:48 PM I think you may be right that it depends on who talks to you....here is the copy/paste of the response I got from Castrol.-----Original Message-----From: Castrol Technical Enquiries [mailto:[email protected]] Sent: Tuesday, 24 October 2006 9:29 AMTo: (Me)Subject: FW: Castrol.com | Technical Enquiries | Technical EnquiriesImportance: HighHi Mildman,Thank you for your enquiry to Castrol Technical.For a Ford BF Falcon Mk 2 XR6 Turbo (4.0L Turbo), Castrol recommendsCastrol Edge Sport 10W/60 engine oil as the primary recommendation, youmay also use Castrol Edge 0W/40 or Castrol Magnatec. Theserecommendations are for the engine after it has been run in, we do nothave the Ford specification for the running in oil, and recommend youuse the Ford genuine oil for run in.The major difference between Edge 10W/60 and Edge 0W/40 is theviscosity, the Edge 10W/60 is a thicker oil than the Edge 0W/40.Castrol Magnatec is a 10W/40 semi-synthetic engine oil which is athinner grade than the Castrol GTX 3 which is mineral oil based 15W/40engine oil.If you have any further queries, please call us on 1300 557998.Castrol Technical.From: BP.com Contact usTo:[email protected]Subject: Castrol.com | Technical Enquiries | Technical EnquiriesDate & Time :23/10/2006 16:29:6Salutation :Mr.FirstName :MildLastName :ManEmailAddress :Mail Address1 :Mail Address2 :City :State :Country :AustraliaPostal Code :Telephone :Fax :Message :I am about to buy a Ford BF Falcon Mk 2 XR6 Turbo(4.0L Turbo).I would like to know what oil you recommend.1: To run in the engine2: To use once the engine is run in.I'm am confused about the difference between Edge 10W60 and 0W40. Alsothe difference between GTX3 and Magnatec.Look forward to your response,
PSYCHO XRT THE PSYCHO XRT Legacy Donating Member 1,275 Member For: 20y 9m 15d Gender: Not Telling Location: At the lights! Posted 26/10/06 12:51 AM Posted 26/10/06 12:51 AM I recently posted a new topic on servicing my T>>>>> http://www.fordxr6turbo.com/forum/index.ph...topic=29591&hl= <<<<<cheers,San.
