  • Member For: 22y 7m 4d
Posted
Just wondering how restrictive the cast pipe that sits under the headlight is? Is it worth having a larger pipe on a boosted application or is it minimal? It looks like the battery tray can be cut up to accomadate a larger pipe.
Thanks
  • Replies 23
Posted Images
  • Legacy Donating Member
  • Member For: 23y 3m 8d
Posted
It would help, however, it really depends on how much power you really want.
I've seen the factory piping (different IC) at well beyond 300RWKW.
  • - Track Bound EVO III -
  • Member For: 21y 9m 20d
Posted
Thanks
that's the one u gotta change :laughing:
  • Member For: 20y 4m 16d
Posted
what size is it? 2in or something?
Posted
about 45mm inside dia  :msm:
macka
Farout, not even 2inches... is there room to sqeeze a bigger pipe in?
  • Colossal Member
  • Member For: 22y 1m 11d
Posted
If there isnt use a bigger hammer :tease:
But as stated before over 330rwkw has been produced with stock plumbing.
Posted
A bigger pipe there may reduce some lag, bring max boost on at lower rpm ect... the max kws may not go up, but it may drive better at lower revs
  • Member For: 22y 5m 6d
Posted
bigger pipe work should increase lag as you have more volume to fill.
Posted
Nup, that's not how it works... a smoother flow through the pipes will reduce lag, and by increasing this small diameter pipe to a pipe the same diameter of the other pipes will reduce the restriction caused by this pipe...
