  • Member For: 23y 3m 24d
Posted
Hello every1,
Just a question.. can I safely get a custom edit with injectors or do I need valve springs?
Regards
Mark
  • Member For: 21y 1m 3d
Posted
Hello every1,
Regards
Mark
Should do the Valve springs. I think most tuners would tell you this.
  • Legacy Donating Member
  • Member For: 23y 8m 2d
Posted
Each car is different and some cars need valve springs done at lower power levels than others. You most certainly can get an edit with injectors done safely. I
f the tuner starts to see valve bounce he will just tune to the power level just below that and then it's up to you if you are happy with that power or want more.
You might want to save up and have them done though as you will want more power down the road.
  • Colossal Member
  • Member For: 22y 1m 7d
Posted
Do you have a mk 1 or 2?
It helps to do the valve springs, but you dont HAVE to. It also helps to have a lot of other things, but you dont NEED them. I guess to reach the potential of having new injectors you will want to do those valve springs.
  • Member For: 21y 6m 8d
Posted
Other things that mean valve springs arnt as much of an issue - a better flowing Cat, or intercooler - reduce pressure on the springs as well.
Posted
Ive got a BF, are these valve springs larger than that of the BA's?
The cat should not be a problem as it is much larger than the stock BA unit
Regards
Mark
  • Colossal Member
Posted
The valve springs are much better in the BF than in the BA mk 1
Shouldnt be an issue for you really at all.
  • Member For: 22y 3m 22d
Posted
What makes them much better, are they the same as the typhoon springs?
  • Member For: 23y 9m 8d
Posted
I've got a Mk 1 with standard valve springs, and I run 265-280 rwkw (depending on the Dyno), and for my car, that seem to be the limit.
This should equate to something in the order of 380 fwkw, so I hope this will give you some idea what to expect
Good luck :unsure:
  • Member For: 21y 2m 24d
Posted
At xxxr6t said MKII springs will change your situation. Mr Ninka has done alot without changing springs yet and this proves xrdreamings point. I would like to know the difference in valve springs between the BF and BA MKII.....and if the typhoon differs
