ugy Legacy Donating Member 199 Member For: 20y 11m 12d Location: Auckland Posted 16/01/06 09:06 PM Posted 16/01/06 09:06 PM Some thoughts please.Whenever I come home from driving the T I automaticaly see how hot theintercooler is and always it is cool or at worst slightly warm. Recently I lifted the bonnet and found that the hose between the IC and the throttle body wasvery hot and the longer the car sat the hotter it got.Surely this is detrimental to have cool air from the IC and hot air to the throttle body. I realize that there is heat soak from the engine which heats up the hosethe longer it sits but if you are taking the car to the drags and sitting in line burnouts..etc, surely the hose must be producing warm air which is not good.It seems to me that the Cobra system where the hose goes straight into the plenum would be the most efficient as there is no heat soak in the hose as itis on the other side of the engine away from the heat.I dont want to go changing the system that I have now and have a question.Would wrapping the hose in header wrap make any difference, or would I be waisting my time and money?Any thoughts would be appreciated. Thanks, Bill.PS...I bought this subject up before but was'nt sure if I mentioned header wrap.
Guest Guests Posted 16/01/06 09:37 PM Posted 16/01/06 09:37 PM The less plumbing the better but what ya gunna do,to change stuff cost you monita...vik...wanna change stuff??? spend some monita,speed costs$$$
bjc Legacy Donating Member 2,823 Member For: 23y 29d Gender: Male Location: Townsville Posted 17/01/06 10:00 AM Posted 17/01/06 10:00 AM It cant hurt wrapping it as the heat from the exhaust does get extreme at times.Brett
DBOSS Faster than any BTA,XTC,Autotech, Nizpro and Tunehouse car Member 3,918 Member For: 23y 3m 10d Location: D SHIRE! Posted 17/01/06 10:02 AM Posted 17/01/06 10:02 AM Sell it and buy a V8
Ralph Wiggum Moar Powar Babeh Legacy Donating Member 19,334 Member For: 21y 9d Gender: Male Location: Perth Posted 17/01/06 02:34 PM Posted 17/01/06 02:34 PM When the cars on boost and running hard do you think the air would have time to heat up? its travelling at very high speed and air is a fairly poor conductor....what do you reckon?
Eugene Member 670 Member For: 22y 16d Gender: Male Location: Newcastle NSW Posted 17/01/06 09:59 PM Posted 17/01/06 09:59 PM When the cars on boost and running hard do you think the air would have time to heat up? its travelling at very high speed and air is a fairly poor conductor....what do you reckon?<{POST_SNAPBACK}>So, if what your saying is true, then an intercooler wont work either?
turbotom Team Bute Legacy Donating Member 1,550 Member For: 23y 2m 17d Gender: Male Location: Adelaide Posted 17/01/06 11:14 PM Posted 17/01/06 11:14 PM When the cars on boost and running hard do you think the air would have time to heat up? its travelling at very high speed and air is a fairly poor conductor....what do you reckon?So, if what your saying is true, then an intercooler wont work either?No Eugene.... What Lucas1 is saying, in practical terms, is correct.Think about the relationship of exposed surface area to volume ratio.....Big difference between an IC and a smooth bore pipe.
Eugene Member 670 Member For: 22y 16d Gender: Male Location: Newcastle NSW Posted 17/01/06 11:42 PM Posted 17/01/06 11:42 PM When the cars on boost and running hard do you think the air would have time to heat up? its travelling at very high speed and air is a fairly poor conductor....what do you reckon?<{POST_SNAPBACK}>So, if what your saying is true, then an intercooler wont work either?<{POST_SNAPBACK}>No Eugene.... What Lucas1 is saying, in practical terms, is correct.Think about the relationship of exposed surface area to volume ratio.....Big difference between an IC and a smooth bore pipe.<{POST_SNAPBACK}>Yeah, I know, I was in a Nasty mood when I put that up, there would be an advantage, but not alot, an IC is designed to tranfer heat, a smooth rubber pipe isnt, but anything you do to keep the inlet temp down will make a difference.18 rwkw just by spraying water on a intercooler, 5th run, engine as hot as hot, sprayed the cooler for about 10 seconds with a garden sprayer, then did the run, 18rwkw, straight up.I think it would help more on the dyno(poor airflow in engine bay etc) than on the raod, but cruising through traffic would be much the same.I have seen a few guys with ceramic coated exhaust manifolds and turbo housing, with a good result in lowering under bonnet temps.Much like running a cooler thermostat with the edit, cooler under bonnet temps.
turbotom Team Bute Legacy Donating Member 1,550 Member For: 23y 2m 17d Gender: Male Location: Adelaide Posted 17/01/06 11:59 PM Posted 17/01/06 11:59 PM too right about under bonnet temps, eug,I think there IS a need for a practical (and neat) method of getting heat out of the engine bay.... especially in modified T's.Some have talked about removing the rubber seals front and rear of bonnet....Any feedback? cheap way out, but how effective?A nice looking bonnet vent/scoop/duct system might be the go. Just so hard to make something which IS functional and actually looks good.tom
ugy Legacy Donating Member 199 Member For: 20y 11m 12d Location: Auckland Posted 18/01/06 01:29 AM Author Posted 18/01/06 01:29 AM Sell it and buy a V8 <{POST_SNAPBACK}>An watch all the T's Pass you buy! <{POST_SNAPBACK}>No way
