I've had a few things wrong with the F6 that have been annoying me of late and after all the BS I went through with the Paint I fell out of love with it a bit and it's kind of wandered from Weekender to battered Daily, so I'm looking for a new daily and have hard parked it on the hoist for a while to chip away at the list of bits and pieces....and it's quite a list...... Waste gate Actuator Waste gate Actuator Bracket Mod Exhaust Manifold/Turbo Mount Studs Engine Mount Bolts Rocker Cover Gaskets Coil Cover Thread Repair Sway Bar link bolts Trans Cooler Mount Trans Cooler Hosing Trans Cooler Thermo Wiring Trans Fluid Levels Sound Deadening Fuel Pump/Boost a Spark wiring Radiator Flush Turbo Drain Mod Passenger Front Door Window Squeaking Steering heat shield Replace Coolant Hoses Flush Radiator Flush Cooling System.... To date I've swapped out the engine mounts (billet mounts are headed to HIPSI) and repaired the threads in rocker cover for the coil cover, which where all stripped when I got the car. PICs- Helicoils in I've also had a Turbosmart Actuator sitting around for a while, so mocked that up and found the bracket I have will need to be cut and welded to correct the angle on the rod Obligatory random progress shots...
