bentles
Everything posted by bentles
im pretty sure bmw have electronic valves.... they > this
problems like this are very hard to fault im afraid... could be a problem with your phone, could be a problem with the car... the thing with bluetooth is there is very little programmed into it, so the dealer cant check it for fault codes... if it isnt playing up at the time of testing there is nothing they can do. they cant just replace the module incase that wasnt the problem, ford will deny the dealers warranty claim if they test the module and nothing is wrong with it.
very common, take it into ford, they should be able to reflash the bpm for you for free if they try charging you, go to another dealer n boycott the first one lol.
cant really say you got 320 till you get it mate.
mine had done 115,000km na then I turbo'd it and done 11,000 since ...... gearbox slips slightly and diff whines a bit but motor still seems strong enough
Sounds good mate I'm looking into spooling mine, as I dont want to upgrade the axles and tail shaft but I want to run it at the drags... If I have to I'll be putting a m86 3.45 lsd in, but I wanna see what times I can run with my diff and stuff first.
I bought a set but then found another set I liked better.... mine are still brand new never used but came with 3 silver center caps and 1 white one for some strange reason lol... anyone want em? 1,000 they are yours... I had em on ebay but they passed in...
lol make sure u do em up on the capri :D dont want caliper issues at 200+ mph lol
they had the ground level ones near chirnside park not long ago... lasted about 2 days then someone painted it or something hahah... then they redid it and I think someone smashed it hhaaha. not sure if its switched on anymore lol... they woulda paid it off in the first week though...
hey mate did you end up putting that spooled diff in yours? how did it go? hopefully ive got a f6 short motor going in soon, and then ill be adding a rapid v3 style setup using bits n peices n aiming for over 300 @ wheels, but that's a long way off yet...
Including the custom tune, flash 3, and some things I broke I reckon I spent around $5,500 give or take... Considering I used a stainless steel catback, monza cooler, and got it flash tuned, also used stewart warner guages for boost and oil pressure, and got a oil filter sandwhich plate, changed the oil at the same time, turbo radiator, and also did a coolant flush.... If I did it again using only standard gear without a custom tune I could have had it done for around $3200 and then if I had of kept everything in good condition when taking out all the older stuff I could have sold for around another $500 in random parts etc..
nah not yet as I need an lsd bad lol... on the street trying hand brake launches stalling to just 5psi with tyres at 18psi they just bake.... lol
maybe when the next model comes out but I dont see it happening any time soon...
Car started out as a 04 BA MKII Futura. After doing lots of research while looking for parts, I realised a few weeks before easter 2009 that I had everything I needed, and the know how to start. I got home from work friday night, started tearing into it. Bonnet off, bumper off, disconnect battery, remove airbox and intake piping, remove cat converter, exhaust manifold off, undid all plugs and looms for the inlet manifold, split in half using long 6mm allen key, removed manifold. Then onto the water lines took out radiator (upgrading to manual xr6t one) undo engine mounts, remove tail shaft, undo gearbox mounts and disconnect shifter cable, starter motor wiring etc and trans lines... remove motor out through the top of the engine bay, and sit it on a tyre (or use a engine stand if u have one. start stripping the motor, heater lines off sump off coils out plugs out, now is a good time to paint stuff if you want (I couldnt be bothered). Then strip out the vac lines for the bbm controls, and there is also a vacuum tank in the guard rip all that out, remove the old PCM (use a hacksaw to cut grooves into the security screws) That was pretty much the night done. Got stuck into it the next day, gutted the butterflys out of the inlet manifold sealed up the hole where the shaft went for the butterflys, put the turbo sump on with new gasket, put the manifold back together bolted up the new heater pipes, bolted up both manifolds, oil supply and coolant to/from turbo pipes... I mounted my oil return later once motor was in because of earth strap/cooler piping being in the way. mount the cooler and mount the under battery pipe and piping etc. If you have a xr6 or a ute you should have the looms needed for the xr6t boost controls... there is a 3 pin plug near each headlight and a 2 pin plug on the shock tower near the oxy sensor loom for wastegate control solenoid. the other 2 3 pin plugs are for boost pressure sensor. If you don't have them get the plugs and there is a loom which connects the pcm's 3rd plug to the loom at the LH headlight. the wastegate control solenoid needs accesory power and needs to be jacked into a pin on plug B of the pcm. (look up workshop manual wiring diagrams if you need clarification. Obviously you have to make the looms yourself if the car doesnt have the foglight loom fitted factory (na xr6's have it so do some xl utes ive seen.) Fit 2bar xr6t map sensor to the inlet manifold using a plug end off a xr6t loom (or failing that nizpro make a converter loom for around the $55 or so mark im told) Use xr6t spec spark plugs (I went for NGK iridium plugs similar to the ebay ones but I got them cheaper at my local parts store) refit coils and coil cover. Refit engine and gearbox and mount your transcooler if you havent yet (you will destroy a 94le 4sp if you don't have an aftermarket trans cooler when u add boost haha) Do up engine mounts (might need a cut down spanner for turbo side, I did) Inlet side is easy to get to. Fit oil return line if you havent yet, fit earth strap, all other wires etc hope you havent forgotten anything yet... Refit all looms and fuel lines etc etc etc car wont run once everything is back together Tow car to ford get a parameter reset done. car should now start with the new pcm. might be stuck in limp home mode this is because it will be throwing a code for faulty speed transducer... set the traction control to off, and then set speed input data to the IC to speedo only (2 settings for traction control both must be set to not enabled) car should work now and drive good... I then got mine custom tuned no exhaust visible. The only problem ive encountered with the car was that it was overboosting which I thought was because of the catback and cooler I had on it, which turned out to not be the cause. Tried getting a custom tune at bluepower however they couldnt control boost at all. I thought I must have made a mistake with my wiring. Turns out when I was cleaning the turbo using mag wheel cleaner I must have got some into the wastegate diaphragm and it caused the rubber diaphragm to harden and crack resulting in no wastegate control. Got the car home, turbo came off actuator changed, put back in and 3psi was held steady. Went back into bluepower for a retune and more boost. Once tuned made 236.3rwkw @ 7psi. boost comes on slow and tapers off this was done on purpose by chris @ bluepower to preserve the life of everything(He is a legend in his own pajamas) 11,000km later and I haven't even had a single problem with the car reliability wise. still running M78 3.27 single spinner, 94le trans, and na tail shaft and cv's. This is my list that I've made up of how to do it. I tried being as detailed as I could but wasn't going to list every single bolt nut and washer or I'd be there all day haha. xr6t heater pipe inlet and ex side 2x o rings for thermostat and waterpump turbo radiator (manual radiator and aftermarket trans cooler) intercooler (monza wog cooler) stock hot side piping stock cold side piping xover pipe stock bov braided oil feed line with filter (or can use stock ford one) + banjo bolt filter setup if using stock line oil return + both gaskets water feed water return turbo sump stock turbo stock manifold stock dump stock cat herrod twin 2.5" into single 3" over diff xr6t ecu boost pressure sensor boost control solenoid 2bar xr6t map sensor xr6t fuel reg xr6t plugs then for the heater pipes u need a new hose and t peice and cut into one of your pipes going to heater core cos they also plumb into the heater pipe on exh side gut the bbm use old oxy sensor (xr6t has diff part number... but that's just cos the wires are longer or shorter I forget which) flash tuner - cos I was running aftermarket cooler exhaust and wanted more power (not 100% needed....) wire for my looms, snipped plugs off mates na xr6, and plug for map sensor. Thanks to BLUEPOWER RACING DEVELOPMENTS. All other work was done in my garage by me and mates.
ive done it myself and have a bit of a build thread going on another forum just wondering if there is a build thread section on here? I havent seen one as yet am I missing something?
peak power is about 16psi but it runs a smidge over 17 below that
it is straight look at the top brackets....
sorry mate, dont know the duty cycle. and as most have said im also guessing the injectors are at there max. but till I build a motor its staying as its power wise...
dude, would you put 375 though a ba1 that's a daily?
hey all, I made just over 300 back in january but wanted more. so added a few more bits n pieces and she pulled a 344.2 on thursday thanks to bluepower racing developments. ive done heaps of mods to the car but ill post just power mods: plazmaman 1100 hp cooler plazmaman hot + cold side piping plazmaman cai with pod process west surge tank and 044 pump upgraded valve springs green top 42 lb injectors t56 6 speed x force 4'' stainless dump x force 5'' stainless cat x force twin 2.5 '' stainless cat back with 2 polished mufflers flash tuner 2 12 psi acuator fg rear turbo housing bluepower custom tune stock bottom end :( prob more but cant think of em at the moment.
haha yeah bit confusing as I share this computer with my house mate (xtt-747) he was with me but we were in my car, orange xr6t, 19's ba xr8 bonnet ect. I takw it your zzz 747?
how did this go with 40psi? interesting to see guys cheers
nah, f**k all out.
spotted a few tuff t's on the hwy last night. zzz 747 , fpv 108, and many more.
no wont fit. how can u fit a 32mm wide disc into a caliper designed for 28mm discs.....
