Jayden7676 Member 84 Member For: 4y 4m 16d Posted 17/06/22 05:25 PM Author Posted 17/06/22 05:25 PM I'm in New Zealand north island , don't Wana say who tuned it as I know plenty he's done and come out great no issues. Over boost was set at 17pound to hit limp mode. With the bigger rare housing and flapper and new accuator , the acuator was done before the tune, shouldn't it have sorted it out? , it's getting a new boost solinoid on Monday and going to run codes again then ,
cat007 Member 236 Member For: 8y 24d Posted 17/06/22 07:07 PM Posted 17/06/22 07:07 PM Does it go into limp mode if you just cruise around and stay off boost?
Jayden7676 Member 84 Member For: 4y 4m 16d Posted 17/06/22 07:25 PM Author Posted 17/06/22 07:25 PM Yeah sure does
hjtrbo Legacy Donating Member 328 Member For: 15y 8m 9d Posted 19/06/22 12:25 AM Posted 19/06/22 12:25 AM Needs to go back to the tuner. They'll sort it. Just guessing games without data to look at.
Jayden7676 Member 84 Member For: 4y 4m 16d Posted 19/06/22 12:38 AM Author Posted 19/06/22 12:38 AM Have done 3 times now and they can't figure it out
Jayden7676 Member 84 Member For: 4y 4m 16d Posted 20/06/22 04:28 AM Author Posted 20/06/22 04:28 AM Update went back today had a new boost solinoid installed , and is still playing up , waste gate keeps blowing open , keeps hitting over boost , has rare hosing upgrade and flapper , 12psi turbosmart accuator bran new , help hah , So I'm having some issues with waste gate pressure being to high and causing limp mode , have had it tuned and back and forth from the tuners for some time now, done boost solinoid upgraded rare housing and flapper and have a 12psi turbosmart accuator in , Has had , full xforce kit , 4 inch dump 4 inch high flow cat and 2.5cat back , injectors done and fule pump , everything is going as it should no weird noises or leaks , hauls ass when it does its thing but keeps going limp mode dew to high waste gate pressure , any thing I should be looking at specifically to try fix this ?
cat007 Member 236 Member For: 8y 24d Posted 20/06/22 04:46 AM Posted 20/06/22 04:46 AM If the wastegate is 'blowing open' then that would suggest you're not actually able to build boost. Possible that the wastegate is not opening at all? Have you got the solenoid plumbed around the correct way? What size spring have you got in the WG? Does the wastegate move freely? Without the car running, use compressed air and (GENTLY) apply a small amount of pressure and see if the wastegate actually opens. A bike pump is an easy way to do this - just don't be trying it with 50PSI (or +100PSI as most shop air systems run on) or you'll break things.
Jayden7676 Member 84 Member For: 4y 4m 16d Posted 20/06/22 04:59 AM Author Posted 20/06/22 04:59 AM It boosts for a couple pulls then goes limp mode , turn car of and back on and I can do a couple pulls again , check engine is on for waste gate pressure high only code it has . Yip accuator is bran new and all set up correctly by the shop and they pressure tested the waste gate before it was installed all is well in that department
cat007 Member 236 Member For: 8y 24d Posted 20/06/22 05:06 AM Posted 20/06/22 05:06 AM Testing it before installation and testing it in place can give vastly different results. A lot of things could have happened during the install. Bent actuator arm, clocked turbo causing binding etc etc. Best to test it in place and confirm it still moves. If the wastegate isn't opening because of a bent arm or something, you're going to get all sorts of issues, some exactly as you're describing....
Jayden7676 Member 84 Member For: 4y 4m 16d Posted 20/06/22 05:48 AM Author Posted 20/06/22 05:48 AM Going back to shop in morning so will have it tested for that then 😄 just that I get a few pulls out of it every time before it goes limp , like it ran 5 mins today fine then did it , straight after being in the shop
