18/08/20 08:08 AM18/08/20 08:08 AM #1 Hi guys, Are people using there old cranks for 1000hp builds or buying brand new cranks. My budget doesn't allow for a billet so I figure best option would be to start with a brand spanker FG crank. Any body else done this? Is it worth heat treating them?
18/08/20 08:46 AM18/08/20 08:46 AM #2 if your budget doesn't allow for a billet crank, then 1000hp at the wheels should not be your aim... 1000hp at the crank the stock crank will likely be fine for a reasonable amount of time assuming all else is done well in terms of the modification pathway.
19/08/20 01:11 AM19/08/20 01:11 AM #3 Author Plenty of barras going around with 700rwkw? with supporting mods of course. cams, ported head, some grout, girdle, torington ect ect
19/08/20 01:17 AM19/08/20 01:17 AM #4 700 is way more than 1000hp at the crank, that's more like 550-600kW at the wheels.
23/08/20 05:41 AM23/08/20 05:41 AM #5 Author Any guys on forum running over 1000rwhp on standard crank and their experience?
23/08/20 05:47 AM23/08/20 05:47 AM #6 there's almost nobody running over 1000rwhp in general... you could probably go through them all and ask them (or read their build threads) what crank they have.
23/08/20 01:45 PM23/08/20 01:45 PM #7 In had my crank nitrided and stress relieved. Notvquitecat 1000, but we had it up to 830 rwhp and had plug issues.. It'll be good for 1000 rwhp. Np....
24/08/20 01:40 AM24/08/20 01:40 AM #8 This crank was also treated to hold 1000hp! My brother’s crank broke at 750hp on Nizpro’s engine dyno 10 years ago. I know of a stock N/A crank that has also broken in half. Its just a roll of the dice. I have 1000rwhp and run a billet crank. As Keith said if you don’t have a budget for 1000 wheel then maybe you should lower the expectations a little. 1000 at the wheels is also a hell of a street car and not really needed to be honest. Edited 24/08/20 01:41 AM24/08/20 01:41 AM by Typhoon
25/08/20 09:52 AM25/08/20 09:52 AM #9 Author On 24/08/2020 at 11:40 AM, Typhoon said: This crank was also treated to hold 1000hp! My brother’s crank broke at 750hp on Nizpro’s engine dyno 10 years ago. I know of a stock N/A crank that has also broken in half. Its just a roll of the dice. I have 1000rwhp and run a billet crank. As Keith said if you don’t have a budget for 1000 wheel then maybe you should lower the expectations a little. 1000 at the wheels is also a hell of a street car and not really needed to be honest. Wow 750 fly wheel is about 400rwkw roughly. I think your definetly right about rolling the dice. I've got two mates running 1150hp at wheels for the last 2 years and haven't let go as yet. In lighter chassis conversions. Did you ever find out the cause? I assume was a built motor.
25/08/20 10:15 PM25/08/20 10:15 PM #10 Back in the day who knows why it broke. Simon held the view for a long time that these cranks were questionable above 7000rpm and that the BARRA had inherently poor harmonics. Clearly things have moved on. The broken crank pictured was a manual car and the crank was advertised as an almost 1000kw capable crank. I have seen an N/A engine with a broken crank shaft right through the middle of the crank, nothing odd about the motor, a relatively clean average km motor. These cranks break, it’s just guys and shops don’t talk about it. I have heard of others too but only ever seen three. For a guy on a budget build then heaps of power can be had on a stock crank, but if it was to break I personally wouldn’t be surprised.
