  • Member For: 7y 11m 27d
Posted
Hey guys.. I have an 07 BF mk11 xr6 turbo it's stock but with dyno tune and no cat.. when I hit boost in 1st and second it's fine but when I'm in 3rd gear at 4000+rpm the car just looses all power and starts to really idle rough and comes good again once cars turned off and on.. what possibilities could this harbour?
  • less WHY; more WOT
  • Site Developer
  • Member For: 18y 5m 18d
Posted
tune probably
  • Site Developer
Posted
can't think of anything mechanical it'd be if it fixes itself after you cycle the ignition.
  • Dropping a turd
  • Legacy Donating Member
  • Member For: 18y 11m 1d
Posted (edited)
Its likely valve springs
Edited by arronm
Posted
How much would valve springs be? It's just thrown a check engine light after I showed my friend what it's doing.. would valve spring fault show on scan tool and would it cut out in 1st and second pulls not just 3rd? Thanks again
  • Site Developer
Posted
valve springs cause rough idle after you've just had a breakdown up in the boost ranges or even sometimes if you've thought boost ranges was OK then if it idles rough straight after then fixes itself after a moment of simple driving... so it might not be valve springs, based on what you've said.
Posted
It'll go from 4,000+ rpm to barely an idle.. I have to pull over and turn car off then start again then it drives fine until again 3rd gear 4k rpm just doesn't like it and shuts down and now thrown a code. Spooky
  • Site Developer
Posted
should happen straight after a 2nd gear pull then slow down to idle and it should be a bit rough... that's a sure sign of valve springs being soft.
Posted
Yeah it does you're right.. if I go sequential mode and give boost in first and a bit in second as I come into third it Goes to sleep. My examoles before was rolling on boost ib third.. how much for springs one would say? 4 or so hundere.. are they hard to fit?
