xr6tnv PC LOAD LETTER Donating Members 388 Member For: 12y 6m 10d Gender: Male Location: Melbourne Posted 20/06/16 04:24 AM Share Posted 20/06/16 04:24 AM Hi guys, Does anyone know if there is a difference between the rear cradle of a BA and BF? I've noticed recently the rear end of my BF mkII makes a bit of noise, especially over speed humps and inclines. Had a look under the rear last night and noticed written in blue marker on the cradle "BA". Never noticed this before and not sure if the complete cradle has been replaced at some point in time. Should I be looking for any signs that a part is not fitted or seated correctly? Cheers Link to comment Share on other sites More sharing options...
FormulaFG Donating Members 68 Member For: 9y 10m 9d Posted 20/06/16 10:33 AM Share Posted 20/06/16 10:33 AM Where is the bolt located on the main centre bush? BA had it off centre located towards the top. BF onwards have it right in the centre of the bush. There are differences between the cradles. Ford tried to make them stronger as they went along because they had a habit of tearing along the centre bush housing. The pick up points are all the same though from BA through to current. 1 Link to comment Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 12y 4m 28d Gender: Male Location: WA, Perth Posted 21/06/16 02:40 AM Share Posted 21/06/16 02:40 AM just recently I was at one of the TUNAs here in WA and they showed me a cradle from an FG. Do you know what surprised me? The fact that the bush housing had torn/ripped all along the bottom part. No not where the welding was, but just a tad above it. Yep the bush housing and the bush were free floating and the owner was wondering why he was getting some knocks. it was unbelievable that the plate could rip like that. sorry to OP for going off topic, but I had to put it out there. 1 Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 7m 4d Gender: Male Location: Perth Posted 21/06/16 02:46 AM Share Posted 21/06/16 02:46 AM BA/BF1 cradles are beefier than BF/2 & FG. The cradles are all basically the same and interchangeable (but you need use FG LCA's with and FG Cradle) But as time progressed the cradles because less solid. BA steel bush cradle is the go IMHO. 1 Link to comment Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 12y 4m 28d Gender: Male Location: WA, Perth Posted 21/06/16 04:30 AM Share Posted 21/06/16 04:30 AM or get the diff hat that Steve got? would that fix the problem? insport or motorsport diff hat, can't remember if that is what it was called. That replaces the housing, doesn't it? 1 Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 16y 5m 3d Gender: Male Location: Probably above atmospheric pressure Posted 21/06/16 09:42 AM Share Posted 21/06/16 09:42 AM Independent Motorsports http://www.independentmotorsports.com.au/ford-tuning-2/ba-bf-fg-diff-hat-upgrade-kit/ 1 Link to comment Share on other sites More sharing options...
xr6tnv PC LOAD LETTER Donating Members 388 Member For: 12y 6m 10d Gender: Male Location: Melbourne Posted 23/06/16 01:16 AM Author Share Posted 23/06/16 01:16 AM On 20/06/2016 at 8:33 PM, FormulaFG said: Where is the bolt located on the main centre bush? BA had it off centre located towards the top. BF onwards have it right in the centre of the bush. There are differences between the cradles. Ford tried to make them stronger as they went along because they had a habit of tearing along the centre bush housing. The pick up points are all the same though from BA through to current. Thanks mate, glad to know that the cradles can be used across different models without any issues. Here is a picture of the main diff bushing.. bolt in the center. Looks to have the metal plate over it and the bushing insert to make it a bit stronger? So the FG cradles only got weaker !!? What a joke ! Wish I had the money to play around with kit Steve got, saw it awhile back and looks great ! Always keeping an eye on your build there Steve to see what's next ! Next thing to do is get it up on stand or hoist and check to see any other suspension issues. Perhaps the the two smaller diff bushings?? Link to comment Share on other sites More sharing options...
xr6tnv PC LOAD LETTER Donating Members 388 Member For: 12y 6m 10d Gender: Male Location: Melbourne Posted 24/06/16 01:15 AM Author Share Posted 24/06/16 01:15 AM Another thought I had was the bump stops making the noise? Are they meant to be quite close to the cradle itself or should they have a bit of room between? Replaced the Ford original ones a few months ago with just replacement ones (keeping the same measurements) but should I try shorter ones? Only change to rear suspension is a set of rear Shockworks non-adjustable shocks whilst retaining the same height with standard XR6 springs. Link to comment Share on other sites More sharing options...
jas98 Member 1,029 Member For: 11y 9m 5d Gender: Male Location: Maryborough Qld Posted 05/07/16 05:08 AM Share Posted 05/07/16 05:08 AM On 6/21/2016 at 0:46 PM, Ralph Wiggum said: BA/BF1 cradles are beefier than BF/2 & FG. The cradles are all basically the same and interchangeable (but you need use FG LCA's with and FG Cradle) But as time progressed the cradles because less solid. I needed a lower control arm (one spring sits on) for the rear of my BA xr6t sedan and at the time I found a brand new one from a FG very cheap. so I have drivers side BA arm and passenger side FG arm. been on for a few years.......seems to work so should I change it or just leave it? they looked pretty much the same haha Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 7m 4d Gender: Male Location: Perth Posted 05/07/16 05:13 AM Share Posted 05/07/16 05:13 AM It'll work great for circle track racing. There's only a couple of mm in it so not likely to blow the car up. Link to comment Share on other sites More sharing options...
