GTX35 wastegate actuator bracket
Featured Replies
#1
I'm fitting a GTX3582R (Supercore) to my G6ET and noticed the standard (3576r) wastegate actuator bracket doesn't line up on the GTX.
What has everyone done to get around this? Slot the holes on the standard bracket? Or does somewhere sell a bracket that fits?
Thankyou.
#2
Cut and weld. I've never seen one line up very well without some modifying. Others may have a better solution though.
#3
I cut the bracket and off the retainer and move it so the alignment is correct then tig it back on.I've also found you usually need to cut the bracket on the 90deg bend between the mounting face and the upright and tweak it then reweld to get the alignment bang on.
#4
  • Author
GAAAY!!!
I thought everything  was supposed to be a straight swap over :(
I think I can make it fit by drilling a new (middle) hole in the bracket and elongating another a little and using an angled actuator rod I have here...
Does anyone happen to have pics of their modded bracket, please :)
Thanks for the replies.
#5
Cut n re weld is the best practice but yes I've seen half decent re drill jobs of the retaining bracket
most people have a drill and bits not many have a welder and some skill but if thinking ahead you can buy an aftermarket bracket from the place you bought the turbo from
any way you go about it just get it lined up straight and preload set correctly
#6
  • Author
Yeah, I've never even attempted to weld anything in my life haha.
I have an MTQ not far away so I might go see if they have a bracket that fits tomorrow.
The actuator I have has the threaded rod on the back and I have an angled arm that looks like it will line up well (fingers crossed).
Is there anything to watch out for when setting preload??
Thankyou :)
#7
Setting preload is an art of the tuner but people insist on doing things themselves these days and can cost you a labor charge if you stuff it up and the tuner needs to re set it.
but a 1/2 hole preload is a good start but don't go anymore than that
#9
  • Author
I decided to get MTQ to make the bracket and set the wastegate up etc but they clocked the front housing wrong.
I've clocked it so it sits like this now (thankfully there was enough adjustment in the actuator bracket, but obviously I'll have to recheck the preload now) :
My question is before I do the final fit and connect everything up...does this position look right for the front housing now?
Thankyou :)
Edited by ***VX*R8***
#10
Everything is governed by the oil feed/drain water feed/drain holes in the CHRA and that's the first thing u want to make sure all line up spot on
then rotate the front housing until it's literally vertically up the outlet ( it needs more counter clockwise rotation by say 5/10* )
then tighten all the bolts up tight on the CHRA and front housing
I would be extremely concerned the preload has changed if they set it and that housing was at the 2 oclock mark and the front housing is the locator holes for the actuator bracket .... And this is extremely vital for not giving the tuner issues
no trumpet over here but I've got this down to a fine art where things should sit by looking at the housing rotations and CHRA
many bugger it up ....
Edited by JETURBO
Recently Browsing 0
