banoonie New Member 2 Member For: 12y Gender: Male Posted 04/11/15 07:11 AM Posted 04/11/15 07:11 AM (edited) Hey fellow forum member, I have a stock BF MKII XR6T which is the wife daily driver, and took it for a drive the another day and found that under heavy acceleration at around 3000rpm vehicle surged badly so I backed off. Took it to mechanic today an he has told me that fuel pressure was all over the place and recommend changing fuel pump and fuel regulator. I will be replacing the fuel pump with a Walbro GSS340 as I plan to do future upgrades (exhaust,FMIC and tune) but I can't seem to find an alternative fuel pressure regulator, will the standard fuel pressure regulator handle 12psi or is there an alternative fuel pressure I can install? Thanks for any responses. Edited 04/11/15 07:12 AM by banoonie
velocityxr6t Member 122 Member For: 17y 10m 10d Gender: Male Posted 04/11/15 07:44 AM Posted 04/11/15 07:44 AM A standard one will be fine for what you're talking about doing. Also, perhaps look at a walbro 460 as an intank pump.
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 13y 1m 17d Gender: Male Location: Adelaide Posted 04/11/15 08:19 AM Posted 04/11/15 08:19 AM Do what bendoco did. He got in touch with herrods and got there pump and fuel reg and is pushing 400 so give them a buzz and see what they can do. His is fg so depends on what year the bf is not sure when they started to use the tank that's in the fg now.
MattyP MattyP Legacy Donating Member 6,317 Member For: 14y 4m 19d Gender: Male Location: Central Coast Posted 05/11/15 05:02 AM Posted 05/11/15 05:02 AM Dont get a pump thatll be redunant at stage 1 Future proof mods and pumps arent expensive. Especially a 460 in standard swirl pot 1
banoonie New Member 2 Member For: 12y Gender: Male Posted 07/11/15 07:40 AM Author Posted 07/11/15 07:40 AM So I replaced the fuel pump with a walbro 400 and larger swirl pot unit and got a fuel pressure reg from Ford. Installing the fuel pump was hassle free, when I got to changing the fuel pressure reg I noticed that the genuine unit had 4.0 bar stamped into the side of it. Just thought I would let you guys know as I thought I read somewhere on here that standard unit where lower than that.
JETURBO ...JD TUNING ADELAIDE... Legacy Donating Member 23,708 Member For: 18y 3m 23d Gender: Male Location: Adelaide Posted 07/11/15 07:44 AM Posted 07/11/15 07:44 AM No mate 4 bar is std ( 58psi ) is what the falcon needs to see in the rail I really don't think you needed a new reg as they are very good reliable item in stock I do think your pump may of been dying Either way at least their new now
KPM Motorsport Member 968 Member For: 20y 11m 1d Gender: Male Location: 2 Dunorlan Road Edwardstown S.A. 08 82999998 Posted 07/11/15 10:35 PM Posted 07/11/15 10:35 PM (edited) HiWe can suggest our Walbro 460 packageIncludes;Walbro 460 high flow high capacity, direct replacement intank fuel moduleHigh flow 400lph direct fit pressure regulator / to correctly regulate the increased flow at correct pressurePlug and play wiring / relay kit / to correctly handle the increased currentThis No fuss properly engineered upgrade fuel system fits as factory and will support a standard vehicle perfectly and should you decide to upgrade in power later, levels up to 420-450 rwkw.$895Contact me dirct 08 82999 998 / [email protected]or purchase olinewww/kpmmotorsport.com.au Edited 08/11/15 11:01 PM by KPM Motorsport
