darcati New Member 16 Member For: 14y 8m 12d Posted 07/05/15 10:56 AM Share Posted 07/05/15 10:56 AM Just came back from a drive to Canberra and have noticed an annoying vibration at highway speeds.It only occurs at speeds above 90-100km/h and only under load and disappears when coasting.The vibration feels like its transmitted through the body and can't feel it through the auto shifter and only slightly in the steering.Apart from Super Pro comfort diff bushes all is stock. Has anyone else experienced this and what was the cause?Otherwise any recommendation of a workshop in Sydney that I can get to have a look at it OTHER than a Ford dealer?Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/90488-fg-f6-auto-vibration-at-high-speed/ Share on other sites More sharing options...
stubbietubbie Filthy weeb Member 1,870 Member For: 12y 2m 29d Gender: Male Posted 07/05/15 11:01 AM Share Posted 07/05/15 11:01 AM Warped wheels? Link to comment https://www.fordxr6turbo.com/forum/topic/90488-fg-f6-auto-vibration-at-high-speed/#findComment-1543518 Share on other sites More sharing options...
darcati New Member 16 Member For: 14y 8m 12d Posted 07/05/15 11:31 AM Author Share Posted 07/05/15 11:31 AM Wouldn't warped wheels vibrate even when coasting? One thing I forgot to mention is the longer you drive the worse the vibration gets. Initially leaving Canberra I could barely notice it but as time went on the vibration was more pronounced, as if something heating up making it worse. Link to comment https://www.fordxr6turbo.com/forum/topic/90488-fg-f6-auto-vibration-at-high-speed/#findComment-1543526 Share on other sites More sharing options...
BenDoCo I'm getten too old for this s**t Bronze Donating Members 4,509 Member For: 12y 1m 8d Gender: Male Location: A big bridge over a river in South Australia Posted 07/05/15 12:04 PM Share Posted 07/05/15 12:04 PM Would a stuffed engine mount cause it? Link to comment https://www.fordxr6turbo.com/forum/topic/90488-fg-f6-auto-vibration-at-high-speed/#findComment-1543533 Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 9m 9d Gender: Male Location: Adelaide Posted 07/05/15 12:15 PM Share Posted 07/05/15 12:15 PM (edited) Egg in a tyre maybe or thrown a balance weight. Its happened to me before.Edit: its not green with a 190k on it? Edited 07/05/15 12:16 PM by Bizkets is fat? Link to comment https://www.fordxr6turbo.com/forum/topic/90488-fg-f6-auto-vibration-at-high-speed/#findComment-1543543 Share on other sites More sharing options...
darcati New Member 16 Member For: 14y 8m 12d Posted 08/05/15 04:30 AM Author Share Posted 08/05/15 04:30 AM Engine mount sounds plausible, cant understand how it gets worse the longer you drive, don't think it would have anything to do with wheels as the vibration disappears when coasting.I'm thinking the uni is stuffed and gets worse as it warms up? Link to comment https://www.fordxr6turbo.com/forum/topic/90488-fg-f6-auto-vibration-at-high-speed/#findComment-1543632 Share on other sites More sharing options...
boost69 Donating Members 737 Member For: 19y 11m 26d Posted 08/05/15 05:10 AM Share Posted 08/05/15 05:10 AM Hmmm...the FPV wheels can buckle quite easy...(have had this happen to me)...even though local tyre shop didn't pick it up on the balancer...when I took it into Ford they found the buckled wheel straight away...not sure if they have more sensitive wheel balancing machines...(Not saying this is the case with you)My symptoms of a buckled wheel were only noticeable at highway speeds, on nice smooth freeway tarmac...Maybe try and get your wheels re balanced incase a weight has come off.From experience a leaking engine mount will give the car a rough idle feel...(as in more noticeable while idling at the lights, than when your moving)Could be an unbalanced tailshaft causing the problem too...(maybe it needs to be rebalanced) Link to comment https://www.fordxr6turbo.com/forum/topic/90488-fg-f6-auto-vibration-at-high-speed/#findComment-1543637 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 21d Gender: Male Location: Perth Posted 08/05/15 05:41 AM Share Posted 08/05/15 05:41 AM I'd suggest driveline related from the symptoms described. May be as simple as a throw tailshaft weight. Gets worse over time as harmonics set in and accentuate the movement. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90488-fg-f6-auto-vibration-at-high-speed/#findComment-1543638 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 1m 14d Gender: Male Posted 09/05/15 04:52 AM Share Posted 09/05/15 04:52 AM I've got a slight vibration at around 90 to 100kph in my FG. Its driveshaft related and gets worse when the car is loaded up. With just me in it I don't feel it. WIth a few fat babes in the back seat you notice it. Link to comment https://www.fordxr6turbo.com/forum/topic/90488-fg-f6-auto-vibration-at-high-speed/#findComment-1543744 Share on other sites More sharing options...
avi8R Donating Members 27 Member For: 15y 9m 10d Gender: Male Posted 09/05/15 11:11 AM Share Posted 09/05/15 11:11 AM (edited) I've got a slight vibration at around 90 to 100kph in my FG. Its driveshaft related and gets worse when the car is loaded up. With just me in it I don't feel it. WIth a few fat babes in the back seat you notice it.My FG is the same. 3 sets of rims, 4 sets of tyres and replaced brakes with new Brembo calipers disc and pads. Superpro diff bushes and still persists. Mechanics and tyre fitters don't seem to pick it up. Thinking of trying new gearbox and engine mounts. Edited 09/05/15 11:12 AM by avi8R Link to comment https://www.fordxr6turbo.com/forum/topic/90488-fg-f6-auto-vibration-at-high-speed/#findComment-1543782 Share on other sites More sharing options...
