  • Member For: 10y 10m 10d
Ive got a 04 falcon into which I am putting an 02 xr6t rear end into. Ive bought these bushes so far through recommendations
http://www.nolathane.com.au/product_detail.php?part_number=49186
http://www.nolathane.com.au/product_detail.php?part_number=49188
Is there anything else I should get for the rear?
and what are your thoughts on front end bushes?
  • Forged Member
  • Member For: 18y 5m 7d
You should do all of them. Every single one.
We Supply and Recommend the Super Pro brand however anything is going to be better than the original ones in there .
  • Moar Powar Babeh
  • Member For: 19y 9m 21d
If you cannot afford to do them all, do the front end and the inner bushes on the rear that cannot be changed without removing the cradle.
But you would be far better off saving your pennies and doing the whole lot.
Im happy to do all the bushes at a later date, however right now im just trying to get the car together and regoed before anything else. But since im taking the IRS out, I might as well do all the bushes that require the IRS to be out, as you said. Which IRS bushes would those be? Sorry im a bit useless when it comes to this stuff, its my first build
http://www.nolathane.com.au/do_segue.php?make=FORD&model=FALCON+%2F+FAIRLANE+%2F+LTD&model_final=FALCON+BA%2C+BF+INCL+FAIRLANE%2C+LTD%2C+WAGON%2C+UTE+%26+1+TONNER%2C+FPV&vehicle=9%2F2002-8%2F2008
  • Moar Powar Babeh
Everyone besides the lca outer, toe control arm outer and uca outter on each side.
So essentially lca/uca/toe control arm inner bushes and all three diff mount bushes
ok yep ive ordered all the diff mounts, and are these the bushes youre talking about?
http://www.nolathane.com.au/product_detail.php?part_number=46204
http://www.nolathane.com.au/product_detail.php?part_number=46203
as for the toe arm, is it also called the 'Rear control arm - upper inner' ? Its got a std replacememt kit as well as a +/- .5 camber kit. Which do I want?
  • To Loud
  • Member For: 13y 7m 14d
I am not sure if this is appropriate or not. I know it ha been posted else where in the forum.
This may help
https://mega.co.nz/#F!loVQwT5D!a_eVD1oUflY1DMd1Gq_MRw
