  • Feeling the Love :-)
  • Legacy Donating Member
  • Member For: 13y 6m 8d
Posted
Hi All, just wondering how accurate the onboard computer is.
I have only recently purchased this car, had 38000klm when purchased, now 42000klm.
Speedo is VERY accurate(within 1 klm per hour at 100)
I had 11klm/100 on average fuel consumption which I had not reset since purchase.
I have been driving it half and half, cruising/fast acceleration since I picked it up (absolutely LOVE it )
I reset the Avg Econ and went for a drive (about 160klm return) which was mostly open road cruising, but also through my town twice (Cairns) on the way there and back.
I saw 8.5klm/100 when on the open road, by the time I had come back home through town I had 8.7klm/100 on the Avg Econ.
To me this seems exceptional for the amount of power I have on tap.
The car does have a 4" intake, pod filter, battery relocation and a aluminum intercooling piping.
Previous owner said there was no other mods done.
Is this a realistic fuel usage scenario, or should I be looking at actual liters I put in the tank to klms I have driven.
  • Member For: 12y 10m 19d
Posted (edited)
They are in their element on the open road, I can go below 10 averages on long open road/highway trips to 15-16's flogging the chit out of it around town/short trips, distance travelled per tank is the most accurate way to work it out.
Edited by barnz
  • Member For: 13y 3m 8d
Posted
Has it had a set of fingerprinted injectors put in? If not you might do even better again. What you've exhibited there isn't common (because of how we drive) but it's certainly not unheard of. With tighter control on all injectors (1000's) and a bigger cooler to drop the temps, I see no reason why you couldn't get even a bit lower. Hell I've seen very high 8's in my stock BF. Around town though at sane speeds it does drink a bit, but that's large cars for ya
  • New Member
  • Member For: 12y 5m 19d
Posted
My car has averaged 9.1 L/100km for a 300km trip on the highway and averages around the 11 L/100km around the city. For the power that these cars can generate, the fuel economy is quite reasonable if driven normally compared to e.g. a Mercedes C63 which would average in the high teens around town.
  • 570Nm @1800rpm
  • Member For: 23y 17d
Posted
The on-board calculation in my FG were within 0.2L per 100km so pretty accurate.
Best and most accurate way to calculate it manually by tracking your fuel used and distance traveled. Reset one of your trip computers when you fill up and next time you fill up you can work out consumption (L/100km) based on kms traveled (trim computer reading) and fuel used (amount of fuel required to fill the tank).
  • Like 2
  • Member For: 13y 6m 2d
Posted
Or if you're lazy like me
Install the Fuel Log app :)
Posted
The drive I did was very sedate, and only overtook 2 cars (not many cars on the road) and I only dragged off a couple of cars in town off the lights.
as far as injectors go, I want to put in a 4" dump and 100cpi cat, id1000 injectors and a flash tune box.
Everything I have read points to these things as the cheapest KW gains.
I want to retain the original cat back exhaust because it is sooooooo quiet and I don't want to draw any unwanted attention
Posted
Don't forget to have a look at the kpm injector offerings. They are compairable, the same or better than an Id. They also are cheaper and are all fingerprinted in Australia
Posted
what is "fingerprinted" ?
Posted
It's what most people refer to as "flow matched" but as I discovered at the kpm evening, they spend a huge amount of time logging all sorts of data on how an injector responds when it delievers fuel at all sorts of speeds, pressures, voltages. Huge amount of data collected. These are then put in matched sets with a data sheet of information which is to be input to the ecu
