  • Legacy Donating Member
  • Member For: 18y 3m 30d
Posted
Big difference between someone who can't tune for sh*t and someone who knows what they are doing lol..
  • Like 2
  • Member For: 11y 8m 26d
Posted
I got it from fordpro wreckers , it was in perfect condition , and still is I released the centre bearing bracket just last week end and checked the rubber for any splits or fatigue and all looks good , the only thing I noticed is the bearing sits low in the rubber closer to the bottom edge of the bearing bracket , is that just the weight of the shaft and bearing doing that or does everybody else's tailshaft sit in the middle of the bracket while stationary ????
Should the sedans have a spacer between the floor and the centre bearing bracket a silly question but just asking because that might centre the shaft inside the bearing bracket and rubber and just wondered if it should have spacers but are missing for some reason
  • ...JD TUNING ADELAIDE...
  • Member For: 18y 3m 21d
Posted
Typically the CB will look like it sits lover to the ground vs floor pan, but it can look "fine" even though its buggered
The thumping u talk of in the take off then goes then comes back thru the mid torque ( mid rpm band ) is a very common CB issue
Any sprints will have one and at approx $80
Utes have spacers between the bearing carrier and floor pan, sedans do not
Posted
Sorry I don't mean to sound like an idiot but what is sprints ????? And do you mean a centre bearing costs $80 ????? I thought they weren't replacable ????
Posted (edited)
Sorry didn't realise its a sa parts place
How bout repco ? Got one of them ?
And yes they cost $80
And yes they are replaceable
Edited by Butt Plug
Posted
Ok now we are getting somewhere , this sounds promising ...... Ok where and who will do the replacement of the centre bearing once I have brought it ??? Sorry for all the questions this problem has been driving me crazy for a while now ....
Ok I will go to telco tomorrow and sus out a centre bearing
Posted
Do it yourself :)
Posted
Some are sealed some are changeable
If u have the spring clips holding the uni cups into the yoke you can change it with a press or good bench vice
If there is no spring clips then its the sealed unit and it needs to go to somewhere like hardie spicer so they can press the old stuff out and new stuff in
Take a pik of what u got and ill tell u how to do it
  • Like 2
