Gearbox/tailshaft Knock At <10Kms With > 30% Throttle.
Featured Replies
#1
My BF xr6t manual has just developed a weird knock kind of like a rubber mallet hitting metal noise very fast if I use > 30 % throttle in first at about ~5 kph but goes away once you get to 10kph. It pretty much only happens in first but will happen in second if you try and do it on purpose. It almost sounds like the tailshaft is hitting something and comes from the back of the transmission where the tailshaft connects to the gearbox output shaft.
The issue started happening after I put some sticky tyres on (265 semi slicks) with over 300 rwkw and took the car out maybe 4-5x for a good flog in the hills.
The gearbox has been pulled out a few times recently so I'm wondering if there are any bearings or bushes that could have failed? Anyone had an issue like this? Where should I start looking?
Cheers
edit: I know my diff bush is cracked however it doesn't knock yet, could this be related?
Edited by rollex
  • Replies 29
  • Views 3.7k
Most Popular Posts
Posted Images
#2
Your centre bearning is toast
Cheers
#3
  • Author
Where is the cheapest place to buy these, ford? Or somewhere like CBC bearings?
Do I need a press to replace it?
#4
Sprints munno have them ( I remember u being norf )
Old one has to be cut out, new one will press in
About $80 from memory
Edited by Butt Plug
#5
  • Author
Cheers
Need to do the diff bushes anyway so might just get a shop to do both at once.
#6
removing the old one was a karnt. I think mines done to. superpro for me next. might aswell do them all when I drop the cradle.
#7
Sure it's not the LSD ? They can knock a bit at low speed like that.
#8
  • Author
Surely not when going in a straight line? It is coming from the gearbox area though
#9
Yes its a "thumping" sound
The CB is knackered, u need to buy the new CB that comes complete in the "carrier" and a new uni joint as u will need to cut the old uni out
The CB "should" tap off or fall off and the new one just seats on then bolting the yoke back on will take it "home" ull needs press or good vice with appropriate cups to get the uni fitted
Simples
#10
check left hand engine mount,easy way ,handbrake on footbrake on ,have bonnet up ,give it a little bit of throttle and see if left side of engine starts to lift up,,cost nothing to check...
Recently Browsing 0
