gaz097 Bronze Donating Members 1,751 Member For: 12y 9m 7d Posted 22/01/15 08:57 AM Share Posted 22/01/15 08:57 AM im about to do this cant you just unplug the line from your surge and connect it to a hose to a bucket and pump the fuel out than reconnect the fuel line and than fill up with a jerry can havnt tried to do this but that's what I was told to doMost definitely if u can be bothered getting under it etc. Other way which is what I did was remove intank pump and suck out all fuel. And leave the plug to the intank pump off and start it and run the surge tank empty. yea I was told to do the same drain the tank and surge when going from 98 to e85 but I'm still not sure about it :/ I want to get on my e85 tune tonight was just going to run it as low as then fill right up with e85 then just flash the e85 tune in and hope it runs lolYeah when swapping over just run it nearly empty then do a full fill. The amount u change the ethanol content by will be marginal. Link to comment Share on other sites More sharing options...
al10s Member 112 Member For: 11y 6d Posted 05/03/15 09:04 PM Share Posted 05/03/15 09:04 PM ive just recently had my car tuned and its currently on the e85 tune,how low do you go in fuel before switching back to 98,on the trip computer.Kms to empty,thanks.Or does everyone just run e85 all the time.I was just curious to see hoe the 98 tune goes. Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 28d Gender: Male Location: Adelaide Posted 05/03/15 09:05 PM Share Posted 05/03/15 09:05 PM As long as its around 30kms to go your fine switching either way Link to comment Share on other sites More sharing options...
al10s Member 112 Member For: 11y 6d Posted 05/03/15 09:23 PM Share Posted 05/03/15 09:23 PM Thanks for that butt plug,ill give it a go today.I might also change my fuel filter.I put a new genuine filter on when I had it tuned probably 1500kms ago.But I believe the e85 may have given the fuel system a good clean out.Are the genuine ford fuel filters ok if you change them regularly,or is there another brand e85 guys use.thanks Link to comment Share on other sites More sharing options...
BenDoCo I'm getten too old for this s**t Bronze Donating Members 4,509 Member For: 11y 21d Gender: Male Location: A big bridge over a river in South Australia Posted 05/03/15 11:11 PM Share Posted 05/03/15 11:11 PM I've heard people say that when you tune for E85, it's a good idea to change fuel filters every 1000 - 1500 k's for 4 or 5 filters coz of that 'cleaning' efect the fuel has. Link to comment Share on other sites More sharing options...
rednose RNS10S Donating Members 2,229 Member For: 17y 8m 12d Gender: Male Posted 06/03/15 12:36 AM Share Posted 06/03/15 12:36 AM If switching fuels for tuning I would run the fuel out before switching.If just switching between tunes then just run down to e or as close as you can and fill right up with the alternate fuel. Link to comment Share on other sites More sharing options...
al10s Member 112 Member For: 11y 6d Posted 06/03/15 01:20 AM Share Posted 06/03/15 01:20 AM yeah,just switching between tunes.To see how the 98 tune goes,im very tempted to just run e85 full time.Hoe about you guys,how oftn do you switch between e85 and 98 tune.thanks Link to comment Share on other sites More sharing options...
rednose RNS10S Donating Members 2,229 Member For: 17y 8m 12d Gender: Male Posted 08/03/15 05:19 AM Share Posted 08/03/15 05:19 AM E-flex daily, the only time I run 98 is if traveling with the family interstate Link to comment Share on other sites More sharing options...
al10s Member 112 Member For: 11y 6d Posted 08/03/15 09:20 PM Share Posted 08/03/15 09:20 PM Im about a quarter of a tank into the 98 tune now,definately less impressive than the e85. 1 Link to comment Share on other sites More sharing options...
Soxtyfoonf6 Member 7 Member For: 12y 2m 7d Posted 24/10/16 08:03 PM Share Posted 24/10/16 08:03 PM Just yesterday I had 30 km left of E70 left in tank , & I changed to my 98 tune , Now I did this prior of going to the servo to get fuel which is just 10 minutes from my place , When the loaded file was finished I turned car on & it would not idle , finally car idled for a while to make to BP servo to fill up , now the car every now & then car drops revs & stalls at lights , why is this happening?? Link to comment Share on other sites More sharing options...
