  • Member For: 16y 4d
Great read Joe & I like your attension to details as well, that fire ring concept has been used in europe in more so BMW's for years one of the many names is pyramid ring or T ring, the great thing about this is you never need to replace the head gasket which is made out of copper & rings again if & when the head has to come back off again you just reuse what you have & unlike the other way that some engine shops are still using theres no need to reciver groove the head so no expensive head work is required.
  • Member For: 12y 2m 16d
Thanks for the input Joe, I'm not surprised that it is European "technology".. I assume that you have used this method before? How did/does it hold up?
  • Member For: 11y 8m 20d
Love all the extra your going to mate all the little things can add up to help a lot more in the end can't wait to see how it goes when it's together.
About the atomic flex plate have you checked with atomic about wether they have changed they way they harden the ring gear as last year another blokes one failed and stripped teeth off the ring gear after around 4 starts of the motor with it. Just thought you would wanna check since how your going to all the extra effort to make sure everything is balanced together.
  • Member For: 22y 2m 19d
I hope those fire rings work out. Where did you get them. In my day could never find them. They look a bit close to the water jacket though.
You didn't touch the flats on the chambers. I know with the Supra mob they used to take out one side (I think the exh side) as it was a souce of something (think detonation). I am talking about very high boost mtrs. But with ethanol not really a problem maybe.
How much attention to the oiling system have you given. I've done mtrs where there has been minimal attention to detail to oil passages to alot of teardroping of every entry and exit hole and the big ends definately were heaps better on the prepped mtr after abuse. A 3mm metal burr grinding bit is your friend here. Some of the oiling holes are not even centered very well so it all needs attention in performance applications IMO.
Edited by turbotrana
Does anyone make a 1/2" one so we can run a true AN8 return line with a sensor?
Not that I'm aware of.. But from memory when I measured the I.D's of all the fittings the ethanol sensor was about 8.8mm with the -8 Teflon hose being around 9.1mm.. The smallest part of my system is the fittings that screw into the KPM module, being 1/4 NPT was about 7.8mm I.d so I think the way I have set it up will be the most efficient for this system
