  • Member For: 14y 2m 26d
Posted
Just curious to see what power levels/odo reading everyone was at when they upgraded their valve springs.
  • Hench, but no longer shredded or tanned.
  • Member For: 19y 6m 8d
Posted
Changed em when I was at 400rwkw/35000, few boys started seeing them hold the car back after around 500-520rwhp (375-390rwkw) but depends on tune/lucky you are really.
  • Legacy Donating Member
  • Member For: 20y 8d
Posted
120k and while mods were being done from standard
  • Member For: 18y 10m 12d
Posted
Mine were giving me a rough idle almost right after getting it tuned at 100,000km (07 BFII). Drove like that anyway for 90,000km and finally changed them in order to go run a 1000m track event :) Now idles fine after WOT runs and also has a bit more power earlier in the revs.
  • Dropping a turd
  • Member For: 18y 11m 9d
Posted
We changed mine when we went over 16 psi.
It's increased boost pressure and soft or soften springs that get blow off their seats
  • Will do skids for food
  • Member For: 14y 11m 2d
Posted
Same here, 13psi was okay, 15psi was not okay.
Car had probably done 30k at the time.
Posted
Im at 330rwkw 15 psi 126,000. Stock valve springs but car is a ba f6
  • Member For: 17y 9m 28d
Posted
Ran stock fg springs making 400rwkw for about 6months but started to lost top end at drags, went from 130mph down to 124mph, that all happened around 40,000km
  • Member For: 15y 6m 20d
Posted
Im at 155000kms. Nearly 340kw at 16psi for the last 20000kms with stock bf f6 springs. No obvious signs of failing.
