  • Legacy Donating Member
  • Member For: 22y 1m 3d
Posted
I noticed my F6 slipped the other day going up a hill on highway in what I think was 5th and ive since been told that GW is known to effect 5th gear frictions.I got a service and trans cooler install done by CMS and was advised that the GW was the perfect option for my power output and is fully approved.Not too happy im now forking out cash to get full flush and GENUINE ZF oil put back in,Im also hoping there is no other damage to box as I don't have 6k laying around to fix a box that could well be caused by wrong oil being put in.
I know there are guys on here that say GW is fine but Is it really worth saving the $250 to possibly damage the box??
What oil does Nizpro and Xtreme use in their box seen as though they seem to be builders of quickest ZF's in the country??
  • Member For: 14y 2m 9d
Posted
your probly the only person that has said this oil has cause problems with 5th gear. are you sure its the oil not just that your box may have been playing up to begin with?
Posted
Im 100% sure im not the only guy who has had dramas with this oil.
There are guys on fordforums who have had dramas.My tuner has mentioned atleast 3 cars with slippage using GW.
  • Member For: 17y 9m 24d
Posted
its slipped once its gonna slip again in the future, time to get it build with new genuine fluid
Posted
Wish It was as simple as just getting box built right now but not really an option at the moment.It didn't slip at drags on Wed night so if it stays like that like for a while and I can save up for built box then ill be happy.I can drive it manually when overtaking on highways now instead of leaving in auto so as it doesn't slip in 5th
  • Waiting for the 1st N/A 12!
  • Member For: 18y 7m 21d
Posted
GW won;t just effect 5th gear Fordy!
Is the flare into 5th or into 4th?
  • Member For: 14y 8m 29d
Posted
Do u still have the "farts" in the box as this affects if the gearbox is going to slip aswell
  • RNS10S
  • Member For: 20y 1m 15d
Posted
I would be confident in saying that the ZF tune in Josh's box is not the issue.
Posted
It flared on Monday when I was doing around 100kmh and slowlt overtook another car.It was in D so im guessing it was in 5th.I tried getting it to flare in 3rd and 4th but wouldn't do it.
