JETURBO ...JD TUNING ADELAIDE... Legacy Donating Member 23,708 Member For: 18y 3m 29d Gender: Male Location: Adelaide Posted 12/11/13 11:30 AM Posted 12/11/13 11:30 AM Hey toads, what is the easiest way u check fuel press on the turbo ? Because its just a PITA location up by the regThe coyote 5.0 is nice and easy though lol 1
IH8TOADS Legacy Donating Member 3,618 Member For: 21y 2m 22d Gender: Male Location: OZ Posted 12/11/13 01:58 PM Posted 12/11/13 01:58 PM (edited) For reference my BA on 15psi at 6200rpm is at 47% Inj_DC on 98ron (0.82 lambda) and 67% on United e85 (0.87 lambda).A FG F6 I logged recently on 20psi on United e85 was at 89% Inj_DC at 6200rpm. Both ID1000's, both untested ethanol content and fuel pressure (was set to 4 bar base).For those running ~24psi at 6000rpm with e85 and 1000's, I'd be wanting to see data on the injector duty cycle.^^Edit. Wiggum's your man for all things mechanical. But quick release fittings and gauge on the join between the hardline and the rail feed is the easiest option on a stock BA/BF. The stock reg and also the return in the factory swirl pot (at the bottom) can play havoc with fuel pressure when big pumps are fitted. Edited 12/11/13 02:02 PM by IH8TOADS 1
Skids4kids in the mid....not the bum like some Member 609 Member For: 13y 5m 6d Gender: Male Posted 12/11/13 09:45 PM Posted 12/11/13 09:45 PM Yep successfully modified my return in the swirl pot recently it was a very easy change tbh.My 044 is a tad quieter now as well.
rednose RNS10S Legacy Donating Member 2,229 Member For: 20y 1m 13d Gender: Male Posted 12/11/13 09:46 PM Posted 12/11/13 09:46 PM So united fuel, ID1000's,GTX3582R an 20psi up top should be safe Toads? Which injector would be the next one up after the ID1000, do not want to go 2000's
JETURBO ...JD TUNING ADELAIDE... Legacy Donating Member 23,708 Member For: 18y 3m 29d Gender: Male Location: Adelaide Posted 12/11/13 10:21 PM Posted 12/11/13 10:21 PM ID 1300 2
flipflop Member 5 Member For: 14y 4m 26d Gender: Not Telling Posted 12/11/13 10:25 PM Posted 12/11/13 10:25 PM The stock reg and also the return in the factory swirl pot (at the bottom) can play havoc with fuel pressure when big pumps are fitted.What has to be done to the return to eliminate the issues you get when running a big pump?. When you run twin 044s does the return need to be modified. Thanks in advance.
Vevapower Waiting for the 1st N/A 12! Legacy Donating Member 2,533 Member For: 18y 7m 18d Gender: Male Location: Sydney Posted 13/11/13 12:13 AM Posted 13/11/13 12:13 AM What has to be done to the return to eliminate the issues you get when running a big pump?. When you run twin 044s does the return need to be modified.Thanks in advance.I modified my return to dash 8 this helped quite a bit.When the car had dash 6 returns even if you screwed the reg right off (which would normally stall the car) the pressure wouldn't drop below 40lbs!Much better now with dash 8! 1
IH8TOADS Legacy Donating Member 3,618 Member For: 21y 2m 22d Gender: Male Location: OZ Posted 13/11/13 06:58 AM Posted 13/11/13 06:58 AM The quick connect to the swirl pot is 5/16th's. Did you put a custom swirl in? The restriction I was referring to was at the bottom of the swirl. You can cut the return tube in the swirl and just cable tie it into place.Red nose, 20psi is safe as. 1
fordpowa Inactive Members 1 Member For: 12y 10m 26d Posted 14/11/13 12:57 AM Posted 14/11/13 12:57 AM If you are having fuel pressure issues and your fuel reg is all the way up then check to see if there is a split in the internal fuel pump hose or a hose near the tank feeding the fuel. 1
