  • Member For: 17y 1m 20d
Really?
Back on the rollers already?
  • Member For: 16y 11m 9d
Yea Getting a emissions tune so I can get the engineering done
But retune will be next week after changing cold side then we are going to push it little harder as I wasn't happy with the result
Well I was happy power to boost wise but not what I want. As I want stronger low to mid
I'm currently make 10rwkw and 40 + nm torque on 2 to 3 p less boost but as I said I want it to be more harsher then it is
  • Spooling Member
  • Member For: 13y 5m 4d
I also had to change my cold side to larger with him, did you inlet temps start jumping when more boost put in? That's what happened with my 2.75" cold side, showed me the graphs and all. Changed to 3inch and netted alot more but also changed to eflex so can't really tell how much difference it made!
Yes I'm going SMASH MY DATE around 20 once change cold side which will be interesting to see. Can't wait. I was speaking with tuner and he was happy to SMASH MY DATE once I upgrade cold side.
But it's Interesting to see from old set up making 18 psi making 391 (25 degree day)
To 405 ( 30 degree day) with more torque across the range on new set up with 2 to 3 psi less boost
If I can make the power I want this heat then I can't wait for some cold weather
